07-21-2014, 04:36 PM | #1 |
Questions about Mel Gross's F-100 steering box conversion.
Guess the main question is: has anyone used this conversion and how does it work for you? Is it worth going through all the effort and expense.
Thanks for your comments.
Fred Kroon 1929 Std Coupe 1929 Huckster |
07-21-2014, 04:45 PM | #2 |
Re: Questions about Mel Gross's F-100 steering box conversion.
I may well be wrong but I was told that Mr. Gross had passed away !
Wayne Last edited by C26Pinelake; 07-22-2014 at 12:14 PM. |
07-21-2014, 04:49 PM | #3 |
Yes, Mel Gross has passed away but his son Randy has taken over. I have a steering box from Randy in my Woody and it is just as good as the previous one from Mel. Randy is good to work with also.
Vic |
07-21-2014, 04:55 PM | #4 |
I have an F-100 steering box that Randy rebuilt in my Town Sedan. Works great.
07-21-2014, 05:05 PM | #5 | |
IT may be expensive, but it is not a lot of effort ! Best of all, in a Model A (roadster) it was something akin to what power steering is in a newer car. At least that's my experience..never would I change back. And , most guys would look at it and never know that it is not stock ! |
07-21-2014, 05:52 PM | #6 |
I have one of Mel's steering boxes in my Vic for about 20 years and it works well. Tom Endy |
07-21-2014, 06:19 PM | #7 |
Can you use the stock horn and light switch with it?
07-21-2014, 07:12 PM | #8 |
This modified steering box is a direct bolt-on replacement for the original Model A box and the installation is very simple and should take a couple of hours to complete. We send complete detailed instructions with every box. On a 1930-31 vehicle you will use your existing steering wheel, mast, spark and gas rods, pitman arm (long or short), horn rod, light switch, and horn bail. The 1928-29 set-up is a little different as the original steering box and mast (Column housing) are one piece. Please either email me at [email protected] or call me at 714-292-8660 for more info. Thanks Randy Gross
07-21-2014, 07:25 PM | #9 | |
07-22-2014, 01:02 AM | #10 |
07-22-2014, 07:01 AM | #11 |
I have one in my 31 s/w works great and great people to deal with.
07-22-2014, 10:07 AM | #12 | |
07-22-2014, 12:08 PM | #13 |
I have one of Mel's boxes in my Tudor. He installed it over 15 years ago. Works great and since my Father had it done I had no idea until recently that it wasn't the original steering box. It steers very easy and looks stock. I think it's an F100 steering box. Mel was a great guy and knew the Model A's well. He's missed by many of us.
07-22-2014, 03:24 PM | #14 |
Our shafts are two pieces. The upper portions are either brand new aircraft quality tubing that we have machined or original Model A shafts depending on availablity. They lower portions are either new aircraft quality tubing or remachined shafts from original F100 shafts. The two are then threaded (tap & die) together to get the proper length. They then are v blocked and checked for run out. Finally they are drilled and pinned welded and then completely welded around the seam. The horn rod will still goes thru. We out source locally the machining and welding. Welding is done by a professional welder.We have never had one break in over 25 years of production. Randy Gross
07-22-2014, 10:13 PM | #15 | |
