06-14-2014, 03:03 PM | #1 |
Cam repair
For those of you that were waiting for me to get the "salvage worn journal model A cams" project going, it is going and works good.
The lobe regrind part will be a grind that is very similar to the stock original grind EXCEPT that it will be modern design and run on one inch lifters. It will also have a larger nose radius so it doesn't wear off like the original grind. I will have a sample of the journal repair for viewing at my shop during the Puyallup meet time. I am 45 minutes by model A from the fair grounds on the road to Mt. Rainier. |
06-14-2014, 03:36 PM | #2 |
Re: Cam repair
Pete, does this basically give a little less lift but more duration?
06-14-2014, 05:38 PM | #3 |
Re: Cam repair
06-15-2014, 10:41 AM | #4 |
Re: Cam repair
pete, is it worth doing? time = money and there still some good cores out there.
06-15-2014, 12:08 PM | #5 |
Re: Cam repair
How about a video for us on the East Coast ?
06-15-2014, 12:12 PM | #6 | |
Re: Cam repair
It will be CONSIDERABLIY cheaper than a new cam. |
06-15-2014, 12:17 PM | #7 |
Re: Cam repair
06-15-2014, 12:44 PM | #8 |
Re: Cam repair
Pete, what does the journal repair involve? Is it spray welded and turned back to standard or some kind of sleeve?
06-15-2014, 01:26 PM | #9 |
Re: Cam repair
06-15-2014, 03:48 PM | #10 |
Re: Cam repair
Sleeving sounds like a good idea . You could probably also sleeve them oversize to take up slack in a worn block as most have.
06-15-2014, 04:00 PM | #11 | |
Re: Cam repair
I have sleeved many cams where the block was bored to take an oversize off the shelf insert bearing. These cams had .480 lift and radius lifters. |
06-15-2014, 05:59 PM | #12 |
Re: Cam repair
06-15-2014, 06:29 PM | #13 |
Re: Cam repair
06-15-2014, 10:29 PM | #14 |
Re: Cam repair
What price range is expected for a refurnished cam compared to a new one?
06-15-2014, 10:34 PM | #15 |
Re: Cam repair
06-16-2014, 02:41 PM | #16 |
Re: Cam repair
Do you post prices? How much including shipping to Michigan?
Wayne |
06-16-2014, 02:47 PM | #17 |
Re: Cam repair
06-16-2014, 04:54 PM | #18 |
Re: Cam repair
06-16-2014, 04:55 PM | #19 |
Re: Cam repair
06-16-2014, 06:47 PM | #20 |
Re: Cam repair
Are you looking for cores, and what is a core worth?
06-16-2014, 08:36 PM | #21 |
Re: Cam repair
The factory did some repairs by hardchroming, I have a cam that the #3 bearing surface is hardchromed, and have seen another with #3, and one with #2 hardchromed
06-16-2014, 08:54 PM | #22 |
Re: Cam repair
Yes, it was quite common in the old days but you can thank the EPA for running the price of hard chroming up now to where many other ways are cheaper.
06-16-2014, 10:19 PM | #23 |
Re: Cam repair
Interesting idea. I have several hundred worn journal cams. Might he interested in having some sleeved. Keep in touch
Steve Becker Berts Model A Parts@ modelastore.com |
Thread Tools | |
Display Modes | |
