Old 04-08-2013, 09:09 PM   #1
Charles Reese
Charles Reese's Avatar
Default Front Brake Lever Pins
what is the 'OD' of A2085 Front Brake Lever Pins? Thanks!
Charles Reese is offline   Reply With Quote
Old 04-09-2013, 12:01 AM   #2
Milton
Milton's Avatar
Default Re: Front Brake Lever Pins
1/4" if I am reading Les Andrews Vol I page 1-32 correctly. Brattons says the same 2013 catalog page 12.
Milton is offline   Reply With Quote
Old 04-09-2013, 12:12 AM   #3
Charles Reese
Thanks ... i was using Snyder's for # reference since Brattons does not use Ford #s.
Old 04-09-2013, 09:38 AM   #4
d.j. moordigian
d.j. moordigian's Avatar
Well....I couldn't find "A-2085" in the PPL's that I have.
Is this the clevis pin for the brake rods? If "yes", then it is .3125" or 5/16".
Dudley
* OK...just had some Coffee.....I'm not sure what size the pin is that holds the
arm too the shaft...*
d.j. moordigian is offline   Reply With Quote
Old 04-09-2013, 03:40 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The closest I can find is:
A-2084 Front Brake Lever........
Front Brake Lever Pin.........Order A-23766.......
A-23766.......1/4 x 15/16 flat head pin...............
Thread Tools
Display Modes
