10-21-2011, 08:33 PM | #1 |
Headlight Bars
It has been brought to my attention that the headlight bars for 28/29 and 30/31 are different. (not counting the pressed steel 30 model) Why is there no reference to this in the Judging Standards? How do you know if the right one is being used? Are they interchangeable? Any help with this would be appreciated, Thanks, Jim
10-21-2011, 08:54 PM | #2 |
Re: Headlight Bars
28-29 straight across,30-31 have an arch to them.Also the originals are split with a seam and drain holes?
www.whidbeymodelaclub.com Last edited by Gary WA; 10-21-2011 at 10:15 PM. |
10-21-2011, 09:12 PM | #3 |
Re: Headlight Bars
I think the early 1928's have a Ford Script on them.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
10-21-2011, 11:53 PM | #4 | |
Re: Headlight Bars
http://www.abarnyard.com/ |
10-22-2011, 12:15 AM | #5 | |
Re: Headlight Bars
If these two images show, as intended, you will see that the 30/31 us curved..first chrome pic; second pic 28/29 is flat as stated above! Hope these help explain to you somewhat. BTW..do not believe that the two are interchangeable. Should also say that you could do anything that you wish...mabe put a v8 flatty and '32 headlight bar on anything !! Last edited by hardtimes; 10-22-2011 at 04:02 PM. Reason: add....... |
10-22-2011, 01:39 AM | #6 |
Re: Headlight Bars
10-22-2011, 08:49 AM | #7 |
Re: Headlight Bars
I put a '30-'31 bar on my rusty '28 yard art because that's what I had and it fit fine.
10-22-2011, 11:06 AM | #8 |
Re: Headlight Bars
I once mounted a 29 bar on a 30. It took some "persuasion" and a few magic words, but it can be done. It puts the headlights up a little higher. I knew the proportions didn't look right, but it took a friend's new set of eyes to point out my goof. All was corrected with no dammage to anything. ( other than my pride)
10-22-2011, 01:11 PM | #9 |
Registered User
Re: Headlight Bars
they must have made some with the 29 bars and 30 headlamps
check out the beauty on ebay right now 120796793990 |
10-22-2011, 02:02 PM | #10 |
Re: Headlight Bars
My 31 Budd cab PU (in my avitar) has the 29 headlight bar on it.
10-22-2011, 05:48 PM | #11 | |
Re: Headlight Bars
To everyone else, thanks for your replies, Jim |
10-22-2011, 11:45 PM | #12 |
Re: Headlight Bars
I got something out of this thread. Thanks for asking the question Jim.
10-23-2011, 02:31 AM | #13 |
Re: Headlight Bars
One said it fit fine and one said it needed persuasion.
Are they the same bolt hole spacing and distance across bolt holes from side to side? |
10-23-2011, 01:16 PM | #14 |
Re: Headlight Bars
And whats the deal on the pressed steel open bottom headlite bar? My Town Sedan has one. Are they original ? If so for what month/year ?
10-23-2011, 02:10 PM | #15 | |
Re: Headlight Bars
In answer to you questions...look for yourself. I say NO and NO! As stated earlier, a guy can and probably has force fitted/whatever onto whatever, but I still maintain...it ain't right(yikes..I sound just like a high points guy!!). to clarify: the 'footprints' are different which is evident, but the spacing of the bolt holes in the 'footprint' pretty much match. Last edited by hardtimes; 10-23-2011 at 02:15 PM. Reason: ADD.... |
10-23-2011, 02:22 PM | #16 | |
Re: Headlight Bars
I have several of these original bars and they are all constructed same. I don't know of any and haven't seen any other type bar construction '28 thru '31. Are you suggesting that their is/are other (original) type construction..not hot rod stuff? |
10-23-2011, 04:27 PM | #17 |
Re: Headlight Bars
Hardtimes, your pics seem to show the 30 as being a bit wider than the 28.
Could you supply a measurement of both, from each top bolthole centre to the other would be good. thanks. I have an original AR here to check, but the 30 bar I have is most likely bent, and don't have an original to check. I am working with glass front fenders and repro fender braces, and am starting to suspect that the holes/bolt brace in the fender brace have been drilled and welded wrong. |
10-23-2011, 05:41 PM | #18 |
Re: Headlight Bars
For all those that are interested, these pictures are of the "stamped steel" headlight bar that is unique to the early 30 cars. I do not know for sure when they started/stopped this feature, but it is an original part, not aftermarket....
The ends are forged/cast, but the bar is flat metal bent over on the top, and is open on the bottom. When I get it off next week, if I remember, I'll take some more pictures to detail it properly. And thanks Hardtimes, you've gone over and above with your pictures and replies! Last edited by Jim Parker Toronto; 10-23-2011 at 05:47 PM. |
10-23-2011, 05:56 PM | #19 | |
Re: Headlight Bars
10-23-2011, 09:53 PM | #20 |
Re: Headlight Bars
pooch,
your back wards, i.e.- the 'chrome' bar is the '30...IT IS SHORTER than the blk '28/'29 bar, BUT is it somewhat shorter lengthwise..due to its bend. I will measure both again, over the top of both for a full length measurement and get back with you ! What this means to me, is that the fenders of the '30 are a couple of inches closer..at the headlight bar attach area....than the '29 fenders..no? Last edited by hardtimes; 10-23-2011 at 09:54 PM. Reason: add.. |
10-23-2011, 09:55 PM | #21 |
Re: Headlight Bars
Tim,
Thanks, for the info. It explains some q that I had too! |
10-23-2011, 09:58 PM | #22 |
Re: Headlight Bars
Jim P,
Your welcome and...thanks to you for being curious! I think that we all can/have learned some because of your curiosity. Looking forward also to seeing your bar in detail. |
10-24-2011, 04:04 AM | #23 |
Re: Headlight Bars
Must have been an optical illusion or too many beers.
But us aussies do the latter. Would be good if you could place one over the other exactly and take a straight down shot with measurements. Today I have cut off the welded hole braces and will let the fenders/bar sit where it fits the best and redrill and reweld. Ahh...repro junk to work with is fun. |
10-24-2011, 09:53 AM | #24 |
Re: Headlight Bars
Doug Clayton's Low mileage Town Sedan was built in May 1930. The issue with these headlamp bars is they didn't withstand the abuse of the common bars so many have been replaced over the decades.
10-24-2011, 10:51 AM | #25 |
Re: Headlight Bars
Thanks to Don and Marco. I have one of these on my April 30 Town Sedan and thought it was aftermarket. Now I won't have to replace it ! Shown is a close-up of the center of the bar, showing it's attaching slots for the plate.
10-24-2011, 05:44 PM | #26 | |
Re: Headlight Bars
Ok , here's what I did just now. I measured both the bars that are pictured Couple of interesting 'things' noted. For instance, I can see how either bar could EASILY be substituted for the other. These measurements are not EXACT, but close enough for what you/I need,eh! I measured STRAIGHT ACROSS both bars ..the centers of the upper square holes: 42" upper hole ctr/ctr '28/.'29 (black) bar; STRAIGHT ACROSS '30/'31 bar 42 1/2" ctr/ctr upper holes. ON BOTH BARS: 2" on ctrs of the two mounting bolt holes. Observations: -even with the bend in the '30/'31 bar , it is an optical illusion that the bars are much different in overall length..with the '28/'29 MABE ONE INCH LONGER..overall length. -there IS a difference in the distance between the light sockets of the two bars....with the '30/'31 being about 29" and the '28/'29 being about 30"; -one final observation, which was an odd one, was that both of my '30/'31 bars have a squared off side to the bottom of BOTH light sockets(as viewed from the bottom of the bar) and that the ''28/'29 bar has ONLY ONE squared off side to one socket..and not the other ! Anyone have a 'guess' what this is about? My guess is that the light socket on the horn side (end) of the light bar needs the squared off surface? But..WHY both sockets on the '30/'31 bars... mabe horns on both sides of some models/did ford change sides for horn position during differing years Anyway, pooch...hope these measurements help youse BTW..beers good ! Last edited by hardtimes; 10-24-2011 at 05:54 PM. Reason: add...... |
10-26-2011, 03:03 AM | #27 |
Re: Headlight Bars
Hardtimes, yup, those figures helped. Thanks.
My AR measures 41 1/2 and at the current arch on the 30 ( I have bent and rebent it to try and get it to fit, is 42 inches, so that tallys with 1/2 an inch bigger. I still reckon the repro braces holes are drilled wrong. I was beginning to think my repro bar was too wide. I will leave it 42. What I need now is a measurement of an original 30 fender brace from , say, top one of 3 chassis holes to lower fender headlight bar hole AND/OR how far does the top of the bar sit to the line in the fender crown. The glass fenders I am working with don't fit the arch of the 28 chassis, I have been told 28/30 chassis are the same except for front crossmember, so the fenders must be made wrong. At least it gives us something to do when nothing fits. |
10-26-2011, 10:09 AM | #28 |
Re: Headlight Bars
that clears some things up, and brings more to question.
do those measurements now determine where the headlight level part of the bar or the later case , center of arch, and how about where over all fender width and hight should land ? seeing some have mixed up parts what does that do ? hoping that these fenders are correct to this frame. i think the headlight bar is correct. wheels correct, spring sag. |
10-26-2011, 12:15 PM | #29 |
Re: Headlight Bars
pooch,
13 1/2" is that bolt to bolt measurement you asked for: i.e.- front top chassis brace bolt to lower brace/fender bolt ...make any sense? BTW...my '30 is early..I think. It has round forged front fender braces. I'm not sure what is correct and/or stock due to MANY statements here regarding assembly line variations and previous owner type changes. Mabe they did come off of the assembly line with different types of braces,eh?? Note: It is apparent that (all) these braces can be BENT also to better match/attach to fender. I can imagine that slight adjustments via bending was/is practiced by assemblers..definitely when dealing with repo junk and/or abused old original parts. If I were you, I'd try to make fenders match good/right light bar and make fender braces match that setup..no? Last edited by hardtimes; 10-26-2011 at 12:23 PM. Reason: add..... |
10-26-2011, 02:35 PM | #30 |
Re: Headlight Bars
I have one cast fender brace for my 30 that is 15" from center of lower hole to the frame to the lower headlight bolt. All 3 holes in the bottom of the brace are the same size. Can anyone say if this is this the correct brace or not? By the way, I need one more!
10-26-2011, 09:07 PM | #31 |
Re: Headlight Bars
four types of head light bars, three types of fender braces, and three types of fenders.
am i getting this right ? from '28 through '31 ? this must have been discussed in a "restorer" at some time along the way. maybe a bulletin ? |
10-26-2011, 11:38 PM | #32 |
Re: Headlight Bars
As far as interchangeable, that is about right as Ford made many things "backward compatible". When you go beyond those basics the numbers jump. Off the top of my head there are about nine subtle variations in front fenders and eight to nine NOT so subtle variations in front fender brackets. It's real easy when you get to the rears!
10-27-2011, 02:13 AM | #33 |
Re: Headlight Bars
8 to 9 different fender brackets , wow.
My glass fenders seem to be from good moulds, so is the frame of a 28 /30 different from about the crossmember forward? |
