12-23-2022, 01:08 PM | #1 |
Weighing and balancing of connecting rod, pistons, rings, wrist pin
I have watched many videos of the weighing and balancing of connecting rod, pistons, rings, wrist pins.
Why do all the videos show weighing each part individually vs weighing the entire finished unit as one piece? Now that I have my pistons out I thought I would for the heck of it balance what I could. For an ice cream getter wouldn't taking the entire rod, rings, piston and wrist pin and weighing it against the others be ok. What am I missing on the procedure? |
12-23-2022, 02:11 PM | #2 |
Re: Weighing and balancing of connecting rod, pistons, rings, wrist pin
One thing you are missing is the wrist pin end is reciprocating and the big end is rotating which makes a different when the Bob weight is calculated for spinning up the crank. Google crank balancing you will learn some more. Modern pistons are within 5 grams or better. The rods will be all over the place weight wise. What you have seen is the way it is done.
12-24-2022, 03:48 PM | #3 |
A Model A is a flat plane crank- no bob weights are required for dynamically balancing the crankshaft. Balance the pistons and pins only for equal weight. Rods need to be balanced in two steps- 1: Big end weight with the rod hanging from the wrist pin and 2: total weight . The big ends and overall weight should be within at least 2 grams of each other.
12-25-2022, 08:10 AM | #4 | |
12-25-2022, 09:38 AM | #5 |
The areas highlighted with black marker is where the factory machined to adjust weight,
the factory machine weighed the chips to know when the target weight was reached perhaps the easiest is a fixture on lathe faceplate, or custom ground cutter on boring bar on milling machine if you look at each rod you will see that area is different on each rod depending on the forging weight |
12-25-2022, 05:34 PM | #6 |
12-26-2022, 12:59 PM | #7 |
The reason pistons are not balanced with rings is that rings are replaced at times, and rings are light nd precision items so each set weighs almost exactly the same per piston. Pins can be switched to help balancing the pistons.
12-26-2022, 05:03 PM | #8 | |
12-26-2022, 06:05 PM | #9 |
Pete what do you mean by" it is taken at resonance?
12-26-2022, 07:16 PM | #10 |
12-27-2022, 11:26 AM | #11 |
Pete, thanks. Of all the engines I have had balanced I have never seen a crank spun up. Interesting about the resonance. Would you happen to have any video of spinning a crank up? Thanks, rick.
12-27-2022, 12:49 PM | #12 |
There are 3 points of resonance in our engines. I forget them exactly but from memory they are about 900, 1200 (?) and 2300. They are heard more than felt.
12-27-2022, 10:28 PM | #13 |
Don't confuse flat plane with non counter weighted. Ford recently did a flat plane crank for the GT350 Mustang as you can see it's counterbalanced.
The A crank would have been better balanced if it was cross plane. |
12-28-2022, 12:46 AM | #14 |
Resonance points are a function of the natural frequency of the rotating mass. You can shift the 1st, 2nd and 3rd harmonic points by changing the mass of the rotating assembly, but you can't eliminate them, just move or shift them away from your operating speed.
12-28-2022, 10:53 AM | #15 |
Many factors contribute to the resonance of the rotating assembly including the torsional stiffness or the crank. The flywheel MOI also influences this greatly.
As for the configuration of the crank, the 4 cyl motor has a imbalance as the piston/rod combination doesn't experience symmetrical acceleration/deceleration at top and bottom of the strokes. The crank layout does not matter, this pic one done for firing order change to utilize the intake ports more efficiently.
As Carroll Smith wrote; All Failures are Human in Origin. Last edited by johnneilson; 12-28-2022 at 10:54 AM. Reason: spelllllling |
12-28-2022, 12:06 PM | #16 |
John, that is a pretty exotic looking bottom end. WOW. For me this has been a very interesting discussion, illuminating!. I would like to ask the brain trust is it my imagination or is the deceleration vibrations, harmonics?, more noticeable when driving a model A than when accelerating. Thanks
12-28-2022, 12:07 PM | #17 |
Three types of vibrations produced by the Model "A's" engine are reciprocating (vertical), rotational and torsional impulse.
Bob Bidonde |
12-28-2022, 12:41 PM | #18 |
with a 180* crank in a 4 cyl. engine there are 2 choices of firing order, 1-2-4-3 or 1-3-4-2. Changing them makes absolutely no difference on the 'putts' going into the engine. No matter which order you choose, each port draws in the same sequence, 1-2 together and 3-4 together. On 4-ported blocks things get better because the ports are separated a bit more.
12-28-2022, 01:39 PM | #19 | |
if you look at that pic closely, this is a 2up/2dn (ala Winfield) crank. The firing order is 1, 3 or 4, 2, 4 or 3. What this does is take the Siamese port and make the crank duration between cyls 360 degrees instead of 180. This really make the Siamese port much more efficient closer to a 4 port design. This really screwed up the cam grinder, it took longer to explain the cam layout required than it took to make the cam. John
As Carroll Smith wrote; All Failures are Human in Origin. |
12-28-2022, 01:45 PM | #20 | |
good question, I have no idea for a stock Mod"A" whether on Accel or Decel, I would imagine it depends on the timing set on accel. I have noticed on a modified motor, that yes accel does have more felt vibration. This I would attribute to the increased combustion stroke energy generated. At 100 HP, you notice it, at 300 HP that's all you feel as your eyes get pushed back into your head. John
12-28-2022, 03:18 PM | #21 |
12-29-2022, 05:08 PM | #22 |
Pete, I was hoping someone might be willing to put up a video of spinning up a crank or even a show and tell on balancing rods!
12-29-2022, 11:26 PM | #23 | |
Minor details will vary with type of engine and model of balancer. https://youtu.be/zwDRGNNl5qk |
12-29-2022, 11:50 PM | #24 |
Follow up:
I balanced the connecting rods (off by 8 grams) pistons (off by 6 grams) wrist pins ( off by 7 grams) and the connecting rod end caps (off by 12 grams) That's a total of 33 grams that i zeroed out. l used a scale that claims it was accurate within 1 gram. i used a scale and did not use the balancing tool that weighs the ends of the rods separately. This may not have been the best way, but it is certainly better than the way it was in the engine before i took it apart. |
12-30-2022, 12:04 PM | #25 |
Thanks Pete, interesting video.
12-31-2022, 12:40 AM | #26 |
I was wondering if anyone was going to do a modern 2up 2down motor. How did that thing run? |
12-31-2022, 11:56 AM | #27 | |
We had issues with ignition and injection in the car and that sidelined the project. The plan is to either run it in a Miller 2 port or another flathead, but that will be determined later. John
01-02-2023, 01:32 AM | #28 |
It seems as though what I have felt in decelaration is the engine rpm passing through a resonant frequency? So if the rotating mass is lightened does this change the resonant frequencies to slightly higher rpms. Has anyone spun up a burtz rotating assembly ? And determined where the resonant frequencies are????
