02-13-2022, 12:10 PM | #1 |
Chevrolet ohv head on a Ford Model A block adapter plate
A machinist friend that doesn’t post on the internet is looking for information on the Chevrolet ohv head on a Ford Model A block adapter plate.
PM me or post if you can help. Thanks Gilbert |
02-13-2022, 12:59 PM | #2 |
Re: Chevrolet ohv head on a Ford Model A block adapter plate
Didn’t Bill Stipe build one ? Look at the Stipe web site!
02-13-2022, 01:05 PM | #3 |
I found this site:
https://thoughtintensivedesign.wordp...valve-model-a/ |
02-13-2022, 01:18 PM | #4 |
02-14-2022, 08:19 AM | #5 | |
02-14-2022, 08:22 AM | #6 |
My first car was a 1927 Chevy. My dad recounted that after 1928 people would put the 28 head on the earlier Chevy motors for more power. My friend in Campbell just sold a Chevy head that was set up to mount on a Model A. The overhead valve mechanism had been modified for oil lubrication from a pipe leading up from the engine block. The original Chevy just had a pad on top of the valves that was saturated with oil and a stamped metal dust cover. Getting the head is the start of the project and there is a lot of work to be done after that. If you can find a Chevy head that has had all the work done to bolt to the Model A engine I think you are dollars ahead. (Or should it be dollars a head?)
02-14-2022, 10:01 AM | #7 |
Neil, based on my understanding, you are correct that prior to 1927, all 4-cylinder Chevrolet engines were a single-port design however I believe the two-port was introduced sometime in early 1927 for commercial truck use and for the Capitol series beginning mid-year in 1927. As I understand it, the biggest difference between 1927 and 1928 two-port heads was the '27 head used a 1:1 rocker arm whereas the '28 head used a 1.5:1 head. Can you confirm this?
02-14-2022, 10:24 AM | #8 |
Hi Brent,
Sorry, cannot confirm changes if rocker ratio. My dad has been dead for many years and I was 14 when I bought that 27 Chevy, which was many many years ago. I will ask my friend in Campbell to see if he knows. My friend in Campbell does not know the answer either. It sounds like the guy with the red Model T, below knows that the more modern heads were 1.5 to 1.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 02-14-2022 at 12:26 PM. Reason: Added info |
02-14-2022, 10:39 AM | #9 |
That's a great article Brent provided. I can only add that the adapter plate could be vastly improved with modern CNC and 3D design to eliminate the step in combustion chamber. I plan on doing this with an Olds head in the future but right now I'm buried in paying work. Please post back if there is anything your friend needs after studying Brent's article.
02-14-2022, 11:47 AM | #10 |
Thanks everyone for the input. My friend is a retired machinist with multiple A’s. He has the Chevrolet Head and would like drawings of the adapter plate and or pictures. He wants a new challenge I guess.
No hurry Brent and I as always appreciate your input. |
02-14-2022, 11:49 AM | #11 | |
I have worked on a Model A with the Chevrolet overhead conversion and made an adaptor plate for my Model T. The 1.5 should be correct. Chevrolet also went to bigger valves. The single port were about Model T size. You used to be able to buy modern rocker arms from; Billy Possum Rides the Web This link has a mix of both T, A and name brand overheads; https://www.google.com/search?newwin...&bih=927&dpr=1 The ones the guy was making, he passed away a number of years back, required a special head gasket to fit the shape of the valve cutouts in it between the adaptor and head. The Thunderbolt plates came in a couple of different compression ratios.
02-14-2022, 11:49 AM | #12 | |
02-14-2022, 12:05 PM | #13 |
At the time we worked on it, were still able to get a replacement gasket. I don't recall any issues with the plate itself, other than maybe a water leak issue and worn rocker arms. The aluminum plate needs to go through several heat/cool cycles before the head is attached. Once the head is installed, the plate can't be retorqued.
The other issue, rocker arms; They were the original Chevrolet and think they were doing the same as my adapter setup, needed to be ground with correct angles to rotate the valves, those pads were badly scored and were too thin. That is why they were replaced. You could also do a search of " Jern Thunderbolt Model A conversion" https://www.google.com/search?client...l+A+conversion If someone does this conversion, make sure they get the water outlet adapter and expect to take more time than would be involved with just installing a ready made overhead.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 02-15-2022 at 12:26 AM. |
02-14-2022, 07:26 PM | #14 |
Neal Jern made the Jern Thunderbolt kit, it was parts to put a Chevy OHV on a model A. I know there were some articles on in in the SOSS magazine. Do an internet search fro Jern Thunderbolt.
02-15-2022, 10:04 AM | #15 |
A few pictures of the adapter plate and graphite gaskets. A friend built one a few year ago and had sealing problems, he ended up having a head gasket made in the NW with copper sealing rings. I can't recall the place that made the gaskets but will find out. Cylinders 1 and 4 have a step as shown in the close up. My thought is to soften that step on the next one to eliminate heat risers in the chamber.
02-15-2022, 01:21 PM | #16 |
'28 is the only year with a valve cover too.
02-15-2022, 03:19 PM | #17 |
Valve covers started before 1928.
Wonder if part of the not sealing is because it was not heated and torqued several times before the head was installed? Could that place have been Olson Gasket?
02-16-2022, 04:10 AM | #18 |
Yes the rocker arm ratio was more on the 1928 head. I went to Neal's place before
he passed away, nice guy. He did more of them for Model T's than A's. As I recall you used a OHV conversion gasket for either T or A on the block and the Chev. gasket on the head side. I also have one of these heads I would sell if any one is interested. Dodge |
02-03-2023, 02:50 PM | #19 | |
02-03-2023, 03:26 PM | #20 |
Just for info, I, too, have a couple 1928 Chevy motors w/ heads for sale, email me.
02-03-2023, 10:52 PM | #21 |
I think they were earlier too - I remember having to take mine off and soak a felt pad that was held to to valve cover with oil to lube the rockers.
I thought there was a guy putting Y block (292-312 V8) heads on the A block but couldn't find anything on it. Here is probably the trickest OHV Model A conversion going. http://victorylibrary.com/mopar/m-table-c.htm#FordY Here is a chart with cylinder spacing - http://victorylibrary.com/mopar/m-table-c.htm#Ford6 |
02-04-2023, 03:16 AM | #22 |
Yes, still have the head. Sent a PM
Dodge |
02-04-2023, 07:31 AM | #23 |
Olsen gasket? |
10-01-2023, 01:13 PM | #24 |
I have kit #50 from Neal Jern's Thunderbolt conversion. I am in BC, Canada.
10-01-2023, 01:21 PM | #25 |
My conversion was running excellently until I made the decision to replace the slightly leaking head gasket with my one and only 'Neal Jern' Chev graphite gasket! Now I have zero compression. Stalled, but not defeated further investigation required. If anyone can assist with a head gasket kit or a source for such kits, I would be grateful!
Thank you, Peter Eglinton. Port Moody, BC |
10-01-2023, 01:27 PM | #26 |
Last edited by buick300; 10-02-2023 at 02:28 AM. Reason: I did not intend to post this |
10-01-2023, 01:29 PM | #27 |
10-02-2023, 02:34 AM | #28 |
I am hoping that someone would have a spare 'Neal Jern"gasket kit for the Model A conversion. I require both head gaskets. Or perhaps someone may know of a manufacturing shop that I can contact. Many thanks. Peter Eglinton
10-02-2023, 08:04 AM | #29 |
Neil Jern was the one that made the 28 Chevy head to the Model A. I had one and no of one more in our club. I just saw something (don't remember where) that someone might be taking up where Neil left of (since he has passed). I will see if I can find out who and where I saw it and post it.
10-02-2023, 08:43 AM | #30 |
Brent,
Thanks for sharing that interesting story re the Chevy head conversion. I enjoyed reading it.
Bob Bidonde |
02-12-2024, 02:24 PM | #31 |
I have a Neal Jern conversion working well (at the moment) on my 1928 Chevrolet running on Ford running gear (except for the head) I will try to upload a picture or video. However, if anyone is interested I can email pictures etc. [email protected]
02-12-2024, 02:35 PM | #32 |
02-12-2024, 03:38 PM | #33 | |
Olson's Gaskets can make gaskets if you have a pattern. https://www.olsonsgaskets.com/ |
02-13-2024, 12:13 PM | #34 |
Wouldn't you just use a normal A gasket under the adapter and a Chevy gasket under the head? If not, why not?
02-14-2024, 12:15 PM | #35 |
Just FYI, the Olds head mentioned above had 3 exhaust ports, and was used by racers back in the day, the first car to attain 140 MPH was Chevy powered, I think with either an Olds head or an aftermarket heat, a 'Tornado'. Neither had a combustion chamber in the head, just cylinder space under the head. Hot rodders of the day used different, longer, rods to raise compression.
04-22-2024, 03:47 PM | #36 |
Hello, I have kit # 50 operating well. It has been a good learning experience for me. initially, I broke some of my 1928 rocker arms, which led me to purchasing Neal's first set of replacement modern style rockers. I can be contacted at: [email protected]
I am in Vancouver, BC., Canada |
04-22-2024, 05:00 PM | #37 |
Kind of interesting topic. I'd be afraid to use this on a T though. Seems like the increased RPM, and power would be hard on the crankshaft. T crankshafts are known to sometimes break.
I guess the surface of the Chevy head seals off the valves on the A block... This does sound like a lot of work. I wonder the difference between the Chevy head and the improved high compression heads avaialable these days. |
04-25-2024, 05:49 PM | #38 |
Gene, you can only go so thin on the adapter plate if aluminum and would depend on the profile in the combustion area compression. I went with just the older style, round holes offset to match the bore and head, not much of a difference.
Olsons as far as I have heard has the patterns to make the Thunderbolt head gasket. While the standard overhead gasket would work between the block and adapter for the Thunderbolt or adapters like it, using the Chevrolet gasket would leave a pocket between the adapter and head between the valve space and over the wedge area.
