03-29-2021, 11:22 AM | #1 |
Welding a bumper
Anyone welded on a "original" Ford bumper?? IF so what wire/rod did you use?? Anything special?? A 35/36 in particular
03-29-2021, 11:39 AM | #2 |
Re: Welding a bumper
Yes, I used 7018 Lincoln electrodes.
03-29-2021, 12:45 PM | #3 |
Eutectic 680
03-29-2021, 02:02 PM | #4 |
Nothing special, all I have ever used for TIG /MIG or Gas welding is ER70S carbon steel weld wire.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 03-29-2021 at 02:08 PM. |
03-29-2021, 02:18 PM | #5 |
I figured the "original" bumpers would be more of a "spring type" steel? I have an "easy grind" .025 general purpose steel wire in my rig now, I just didn't want my "fill welds" popping off!!!
03-29-2021, 02:36 PM | #6 | |
Only thing to consider is removal of chrome plating in the area of the weld.
03-29-2021, 02:38 PM | #7 |
I assume your going to have it chromed? If so, weld it up but don’t try to grind it down before taking it in, let the chrome shop do it. If you’re going to paint it then get after it.
03-29-2021, 02:59 PM | #8 | |
Thanks for everyone's input!!!! Last edited by rockfla; 03-29-2021 at 03:07 PM. |
03-29-2021, 03:18 PM | #9 | |
03-30-2021, 08:04 AM | #10 | |
all 4 sides of the weld areas. I would preheat the weld areas.Tack weld the bumper together and thin down the tacked area with a grinder' Position the pumper so you are welding down hill at at a little better than a 45 degree angle. Weld and grind smooth. I think if you heat the welded area to cherry red and quinch in ice cold water it will have the spring back in it. Use MIG G.M.
www.fordcollector.com |
03-30-2021, 09:19 AM | #11 |
Make sure you grind off all the old chrome before you weld it. Use a respirator for both the grinding and welding as chromium can be harmful if inhaled.
03-30-2021, 09:33 AM | #12 |
03-30-2021, 09:44 AM | #13 |
Yep' the only thing I ever do is heat the weld area to a dull cherry red and let air cool to normalize the weld. (but not always)
12-02-2023, 06:04 PM | #14 |
Ok so I read this post and start working on my 1939 bumper and it shattered. My bumper has extra holes where something was bolted on. Before welding up the holes I put it in the press to push a dent out and the bumper shattered like I was trying to bend glass.
YMMV but it seems this bumper is very brittle so now I have to weld it back together but in my experience with steel like this (bed frame angle iron) it will crack right at the weld. Do I persist of try and find another bumper?
I am building a 1939 1 ton express |
12-02-2023, 07:08 PM | #15 |
I have always thought bumpers are spring steel, and don't take kindly to welding. Like welding a leaf spring, usually breaks. perhaps heat it cherry red first to take out the hardness.
12-02-2023, 09:10 PM | #16 |
The bumpers through at least through the 1936 variety are definitely spring steel. That's why they are a challenge to straighten once bent.
12-03-2023, 10:50 AM | #17 |
Does 38 Deluxe passenger bumper fit 39 1 ton express??
12-03-2023, 11:20 AM | #18 |
Yes sir, and through at least 1940.
12-03-2023, 04:10 PM | #19 |
Rely on DavidG and Kube's comments as they are true.
12-03-2023, 05:32 PM | #20 |
I've found that using bed frame rail is a nightmare too, hard as heck & hard to weld too.
12-03-2023, 05:38 PM | #21 |
I never had a problem welding ed rails; they make great battery boxes. Maybe it's because I use an old stick welder?
12-04-2023, 07:46 AM | #22 |
Maybe those hard to weld bed frame rails were "work hardened".
12-04-2023, 10:08 AM | #23 |
04-08-2024, 06:23 PM | #24 | |
