10-21-2020, 05:35 PM | #1 |
Oil Breather tube 20 inch flex tube
Greetings and salutations; what are the people's thoughts of adding a oil breather flex tube to your engine? Wife and I went on a 75 mile ride this weekend and all she did was complain about the smell of oil flumes in the car! Do I add a breather tube or don't let her ride anymore?
10-21-2020, 05:40 PM | #2 |
Re: Oil Breather tube 20 inch flex tube
Breather tube....it'll be cheaper in the long run.
Bob-A |
10-21-2020, 05:45 PM | #3 |
Breather tube really helps. Keeps firewall clean, no funny smells.
Enjoy. |
10-21-2020, 05:48 PM | #4 |
How much blow by do you have? Engine overhauls aren't cheap, neither are divorces !
10-21-2020, 06:20 PM | #5 |
Like mine -- the only problem I had was when changed oil, didn't put the funnel down far enough, before discovered oil I was adding was going to the floor thru the breather line.
10-21-2020, 06:50 PM | #6 |
10-21-2020, 07:47 PM | #7 |
Put the breather tube in, remember happy wife = happy life.
Adjust your points with gentle blows of a 2 pound hammer |
10-21-2020, 07:57 PM | #8 |
Maybe SHE needs the "breather tube". Seriously though, I have one on my A and I don't notice any oil fume smell in the car.
10-21-2020, 09:34 PM | #9 |
Several friends that have did the "divorce thing" all agree, "Cheaper to Keep'er"
10-21-2020, 09:53 PM | #10 |
Installed one about 4 years ago, really helps with fumes and oil mist. I like to keep my engine compartment tidy. This picture was taken about a year after the install. A long neck funnel is needed for oil changes.
10-21-2020, 09:58 PM | #11 |
You'll be able to stop the fumes coming in by opening the windscreen a little and closing the other windows, assuming you are in a closed car. Doing that gives a slight positive air pressure in the car and stops the fumes entering. I do that to stop the HOT air coming in around the pedals. (On a RHD car, the exhaust pipe is between the clutch and brake pedals)
10-21-2020, 11:03 PM | #12 |
I have very little blow by from my engine so there was hardly any smell, but my wife could smell it. The breather tube helped.
10-22-2020, 03:41 AM | #13 |
Geee, it would be cheaper to leave the wife at home. Those breather tubes are $35.00.
Actually I installed one and they work great. |
10-24-2020, 07:29 PM | #14 |
Thanks for all the positive responses! The engine is a fresh rebuild, but the wife has a sensitive nose! I'll tell to let Santa get one for Christmas
10-24-2020, 09:10 PM | #15 |
10-24-2020, 09:57 PM | #16 |
If you keep your eye out you may find a FUMAZE at a swap meet. There are originals and reproductions.
The originals have are marked FUMAZE PAT. PEND P.O.B. MFG.CO CINN. O. and the tube is seamed. The reproductions are marked FUMAZE PATENTED IN USA, and the tube is not seamed, it is solid pipe. see below photos
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 10-24-2020 at 10:07 PM. Reason: added photo |
10-25-2020, 12:01 AM | #17 | |
Ruth "Sometimes you really DO need to read the whole thread" |
10-25-2020, 12:24 AM | #18 |
A total rebuild is funner and a whole lot cheaper. Also can be justified as it's for her.
Because Dear I love you. |
10-25-2020, 01:42 AM | #19 |
No alterations to your engine pan. In fact, the engine pan adds to it's effectiveness. I've been using one for 10 years now. works great!
10-25-2020, 02:05 AM | #20 |
kick her ass to the curb. Once you fix the fumes problem she’ll find something else to complain about.
10-25-2020, 04:05 AM | #21 |
There's the Stipe one
https://www.specialtymotorcams.com/d...by-control-008 |
10-25-2020, 07:51 AM | #22 |
What about running a hose with a PCV valve over to the intake manifold?
John |
10-25-2020, 02:59 PM | #23 |
I once thought about using a PCV but decided not to . If I used the PCV it would cause the engine to have to reburn the fumes . I figure burning the fumes would slightly weaken the charge in the combustion chambers and help the spark plugs to stay oily and weaken the spark . Too hell with the fumes , I use a Fumaze !!!
10-25-2020, 05:01 PM | #24 | |
10-26-2020, 12:13 AM | #25 |
Not to mention sucking all the byproducts from combustion from your crankcase (unburned gas, water and acids). It's a good thing!
