11-21-2019, 08:03 AM | #1 |
Front Flexible Brake lines 20" Long ????
Hey, so i ran the rear brake lines to meet at the radius rod and it will go up its length. Looks good! Now, The front it seems im going to need a rubber line about 20" long to go from the front wheel cylinder to some kind of little bracket i will make that will go under the frame rails. Dont want to drill a hole through the frame rail. Not sure what this should be. I am using 1/4" hard lines and flaring them myself so i have complete control on their lengths.
Has someone done this same thing and maybe they have a part number of one? Or can guide me to a source? Thanks! |
11-21-2019, 08:25 AM | #2 |
Re: Front Flexible Brake lines 20" Long ????
Your local NAPA, maybe.
11-21-2019, 08:29 AM | #3 |
11-21-2019, 08:33 AM | #4 |
You got that right, my local NAPA has one guy that is flathead savvy, and he goes out of his way to help, when he's not there it's a crapshoot.
11-21-2019, 09:34 AM | #5 |
A good Napa store, like I have, will take the time to look up a special application part. I'm grateful every time I go there that I have parts people willing to go the extra mile. The parts books at Napa have diagrams along with specifications (length, fitting size, etc.). All they have to do is go to the right book with brake hoses(such as a Wagner brand book) and do a little research.
Check e-Bay seller "goodbrakes". They are also known as Brake Hoses unlimited. Let them know what you need and you will probably find it. Last edited by TJ; 11-21-2019 at 09:40 AM. |
11-21-2019, 09:49 AM | #6 |
Have a look. Mart. Edit: macs have 2 part numbers listed. https://www.macsautoparts.com/early_...ial-truck.html and https://www.macsautoparts.com/store/...Product_Viewed They are 18-1/4" long, that's what I used. don't know if they are the same or different. It's the rear hose for the 42-47 trucks. Rockauto also have 'em. Mart. Last edited by Mart; 11-21-2019 at 10:11 AM. |
11-21-2019, 09:53 AM | #7 |
After reading some other forums have a part number that should be what i want. (Raybestos or Wagner # BH25629) I called NAPA with the number and they are going to get me two. $21.95 each. I was expecting it to be more. Ill follow up either way if this is indeed what i need. Maybe someone can use the info too...!
11-21-2019, 09:58 AM | #8 |
NAPA part # 36502 should work for you. It's 20.875 overall with the 7/16" - 20 on the wheel cylinder end and 7/16" -24 (1/4" female inverted flare) on the frame end. the next shorter is # 36564 at 18.688" long and both use a # 80742 hose lock clip. Part #25664 is 20" long #4000 is 19.25" long but both use a 5/8"-18 nut to attach to the frame bracket.
The 25629 is 21.1" long if this all helps |
11-21-2019, 10:10 AM | #9 | |
WOW! Thanks for the detail! I look into these! |
11-21-2019, 11:33 AM | #10 |
Hi Nick,
I agree with others here about finding a good NAPA or OReilley's store. I ran into this five years ago and don't remember how I found the hose. I know it was with lots of searching and may have been from my local and good NAPA store. I found that hose just under 18" long worked for me. I hear you on drilling holes in the stock frame but I did so for brackets I made as you can see attached. These are the specs on my hose: Product Details Part Number: 88215 Brake Hose Length (in): 17.625 Fitting Size (1): Male - 7/16-20 Fitting Size (2): Female - 7/16-24 Also for reference https://www.speedwaymotors.com/Brake...ds,104755.html I searched online and couldn't find anything helpful of hose specs to part number cross reference. Glenn |
11-21-2019, 11:43 AM | #11 |
Just saw all the other posts while I was drafting mine. Great info on the NAPA numbers which I've saved for the future.
Thanks |
11-21-2019, 12:13 PM | #12 |
The days of the old time counterman that knew parts is over. When guy's like us, that are building hot rods and custom cars need something we have to do all the work ourselves. Any tome I go to our local auto part store and give them dates like 1932 and 1946 the first thing the kid says is we don't have it.
11-21-2019, 01:04 PM | #13 |
I got mine on Amazon, better price and made in Mexico.
11-21-2019, 02:26 PM | #14 |
I went to a new recently opened O'Reilly's here with a part # from THEIR website. Kid couldn't tell if they had it in stock........................
Paul in CT |
11-21-2019, 04:53 PM | #15 |
11-21-2019, 05:01 PM | #16 |
11-21-2019, 08:42 PM | #17 |
I use napaonline and spend a little time searching for brake hoses and use their part numbers to figure out what number is the length. Keep looking until I find one that works. NAPAonline has helped me find a lot of parts. I have a NAPA warehouse near me that has a store with it. Very convenient. No, I don't work for them.
11-22-2019, 06:27 AM | #18 |
Thanks to all for this information!!
11-22-2019, 09:12 AM | #19 | |
11-22-2019, 09:16 AM | #20 |
You need two copper washers. Ford part # 91A-2149 most every ford parts dealer will have them. Or you could likely match one up locally
11-22-2019, 09:26 AM | #21 |
11-22-2019, 09:27 AM | #22 |
They go on the wheel cylinder side.
And, if you haven’t run the hard lines to the master cylinder brass block yet, you’ll need two there as well, they go on each side of the brass fitting. They are a bit more special and likely you won’t match those up locally. The part # on those is 91A-2152 and 91A-2151 |
11-22-2019, 09:36 AM | #23 |
There seems to be a major price difference between the earlier wheel cylinder thread size and the later (F1) size! I use the F1 brake setup and the brake hoses are around $7 at Rock Auto and $13 at NAPA.
11-22-2019, 09:56 AM | #24 |
Yeah, it's just a 7/16 bore copper washer.
11-22-2019, 10:39 AM | #25 |
On Napa or Rockauto I'm sure the earlier ones are more expensive, but likely not from a Early Ford Parts supplier like Joe's, etc... We retail the 1939-48 Ford fronts for $13.95 a pair.
11-22-2019, 10:52 AM | #26 |
