10-28-2019, 06:50 PM | #1 |
Carbon build up inside intake bores?
I took the 4 barrel intake off my 8BA to change to Tri-Power intake. Motor has less than 3000 Miles. Inspected intake valves & springs which looked fine. I was surprised to see carbon build up in the intake bores that line up with the intake manifold between where they mate & the valve stems? No combustion S/B happening to create carbon in those bores? Maybe valves leaking igniting gas vapor in passage ways? Assuming needs disassembly to clean carbon to keep carbon pieces out of cylinders? What’s going on?
Nomad |
10-29-2019, 10:28 AM | #2 |
Re: Carbon build up inside intake bores?
Could running rich cause that?
10-29-2019, 01:04 PM | #3 |
Depending on how hard you drive it...valves floating give you issues like that...
Burnt valves or a hole between heatriser and intake would make the car run bad... Does it run as it should ? |
10-29-2019, 01:44 PM | #4 |
Always ran well, smelled a little rich but thought that was the nature of the beast. Never pushed it real hard. 3500rpm-4000rpm shifts occasionally. Engine has fewer than 2500mi’s
Nomad |
10-29-2019, 02:33 PM | #5 |
From experience,its sucking oil up or around the guides
Lawrie |
10-29-2019, 03:33 PM | #6 |
Nomad |
10-29-2019, 03:34 PM | #7 |
One of the big culprits causing the problem Lawrie mentioned is using the engine "coast down" as a method of braking. The crankcase pressure can push oil up the guides/valves and into the port. Most of my experience has shown the accumulation of carbon on the valves, rather than the ports.
There is also something to be said for valve timing, but that is a big subject and might not be associated to your problem.. |
10-29-2019, 03:40 PM | #8 |
I agree with the other guys. Worn guides and way to rich.
It should have stunk when it was running too. |
10-29-2019, 03:54 PM | #9 |
In hindsight yes it smelled rich, but the older cars all smell rich compared to the modern computer controlled fuel injection. I have a ‘67 442 runs perfect but smells a lot more than my ‘07 BMW. Guess I thought it relative as old to new engine science. Beside a few typical issues the 8BA always ran, idled & accelerated great! I do admit to what JWL mentions & do use the engine & Tranny compression braking to slow down especially w mechanical brakes.
Nomad |
10-29-2019, 04:22 PM | #10 |
Question is: Do I just surface clean the intake ports lightly removing loose carbon w wd40 or spin a wire wheel on drill to clean all? If I do are precautions like shop vac running on each at same time enough? Or is it break engine down clean polish ports then clean block & reassemble engine time?
Nomad |
10-29-2019, 04:43 PM | #11 |
Did you change camshafts recently ? If it has a cam with a lot of overlap (intake and exhaust valves opened at the same time), then it's possible to have reversion in the intake which is backwards pulses from the exhaust. I had the inside of an intake manifold turn black because of this.
Sal |
10-29-2019, 05:37 PM | #12 |
For personal interests, would MMO or Sea Foam help keep such deposits from forming?
10-29-2019, 05:52 PM | #13 |
I haven’t. U could b right on the valve timing? I’ve heard same w modern perfed engines. I have several classics & work on them but never had One w adjustable solids so no experience there. I stumbled into the Flatty thing when my 90 yr old Mom’s 80 yr old widowed girl friend had a car she wanted me to look at & let her know what I thought she’d get for it. Thought I’d be checking out a Pontiac Parisian or something. Turns out to b a 60k mile ‘35 Tudor in her heated garage for 30 yrs perfect condition since her husband died. Missing engine ( another story for another time). I could of got it for $2k but as was Mom’s friend gave $6500. So found a Flatty builder ( Jerry Livingston owner of United Engine Specialists) & had an 8BA perf’d up a bit built 5 yrs ago. He put a 3/4 isky cam & adjustable lifters. Got under 2500 miles on it. So, probly should put 4 barrel intake on it get rid of it & put a Sb Chevy (more my territory) in it. Probly gut reaction cause not a happy camper right now!
Nomad |
10-29-2019, 06:21 PM | #14 |
I'm not real smart but if the exhaust stinks, I would think the engine is running to cool if the plugs look good.
10-29-2019, 06:46 PM | #15 |
Kind of weird. When I saw carbon buildup in the ports I pulled a head to see if carbon extended to valves. Saw some but minimal so thinking Lawrie had it right. But also pulled plugs on same side & 2 were a nice light toast color & two were black? I have a temp gauge on each bank and one coming off radiator push side in the dash. Runs at 180-200 pretty consistent.
Nomad |
10-29-2019, 07:00 PM | #16 |
if you want to get rid of the carbon get a coffe cup fill with water. bring eng rpm up to about 1500 rpm pour the water down the carb slowe you don,t want to stall the eng do that when ever you think the eng needs it
10-30-2019, 01:54 AM | #17 |
Better than a cup would be a restricted flow, ketchup squirter or any squeeze bottle. This to control volume of flow. Higher RPM would also be better.
Never want to add too much, at a time. I once killed a good motor. Boo Hoo. I did however perform many 'miracles' In the day.
Enjoy yer day. Tom Hate can't fix what it started. |
10-30-2019, 02:30 AM | #18 |
Over a few years in my 33 babbit engine, I had this problem.
My fault first up, using old guides and valves. next try better valves . still same problem, 3 rd try (slow learner) good valves and guides,better.but still would oil up and on a LONG down hill blow smoke at bottom. Fitted new straight valves and guides with bronze liners in the guides and seals on the inlet valves, No problem from then on. The current engine in the 33 (99a),first I still tried the old mushroom valves and split guides for a while but it would oil a plug or two on trips, did the same as the old engine with new straight valves and guides with the seals on the inlets and bronze liners, that engine has done about 70000 klms ,uses no oil runs great. Lawrie |
10-30-2019, 04:39 AM | #19 |
And Lawrie said :
straight valves and guides with the seals on the inlets and bronze liners, that engine has done about 70000 klms ,uses no oil runs great. The answer i believe ...... |
10-30-2019, 05:55 AM | #20 |
We began addressing this very issue with my own F-1 back in the late '70's, got totally fed up with "hanging" valves in the 239" during long periods of storage. Needed to come up with a sure fire fix!
Took all 16 guides out and lined them with the K-line bronze liners! Machined all 16 guides for some "Perfect-Circle" rubber/teflon valve stem seals, today we do the 8 intakes only unless customer wants all 16 done. We've learned over time the exhaust's weren't necessary. Since we began this procedure we've probably used/sold a couple thousand or so! The bronze liners in conjunction with some stainless valves was one of the best moves we ever made on the Flatheads! A very close friend of mine back here on Long Island built nothing but Flatheads, we worked closely with him on all the machining, he would bring us about 10/15 a year back then? Every single one of his builds got the S/S valve/bronze liner pkge! Thanks, Gary in N.Y. P.S. Here's a couple shots (again) on the package, valves, lined guides, and today's Viton stem seals! We stopped using the rubber/teflon a few years back now! The Vitons are easier to install, no "sleeves" involved!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
10-30-2019, 09:50 AM | #21 |
So it sounds like the carbon buildup in the intake ports was a common issue. Not sure what I’m gonna do, kind of bummed out right now. Thought I was gonna do a relatively simple fun intake switch & turned into a major cluster F project & $’s I wasn’t planning for.
Thx for all the valuable info!
Nomad |
10-30-2019, 11:47 AM | #22 |
Questions on reinstalling heads. Can I reuse the head bolts? Whats the best sealer product for the head bolt threads where they need to seal from water jacket?
Nomad |
10-30-2019, 02:16 PM | #23 |
Headbolts can be reused if they wasn´t abused being overtorqued.
Sealant is like flavour of icecream...we all have our favourite...i use loctite threadsealer...permatex or any pipethread sealer should do the job... |
10-31-2019, 04:19 PM | #24 |
So I’m not gonna pull the guides out, but I am gonna stop compression braking per Lawrie! But I got an idea after seeing a video on which is better Seafoam or Mystic to clean carbon by poring into carb. He took carboned up valves & put them in a jar of each & both dissolved the carbon! As I have the problem cyl. bdsank opened w head off & see the carbon in the ports I think I can pour / puddle some in each port to dissolve carbon then suck out w shop vac? What do u think?
Nomad |
11-03-2019, 08:54 PM | #25 |
This Berryman's Chem-Dip ought to take care of your carbon. Check-out this video...click the link below! DD
https://www.youtube.com/watch?v=voe-ZcKjg4Y |
11-03-2019, 09:46 PM | #26 |
Nomad |
11-04-2019, 01:39 AM | #27 |
Try oven cleaner
Lawrie |
11-04-2019, 05:13 PM | #28 |
Would not doing anything be an option? Was it really causing a problem? You know what it is and it shouldn't really cause a problem, (or have I missed that?) so why not just leave it alone?
Just giving the alternative viewpoint. Mart. |
11-04-2019, 05:57 PM | #29 |
I can tell you from experience it WILL cause a problem.
On the 33 original babbit engine that we used in the 33 for a long time. I had it rebuilt but used the best old valves and guides.(dumb) We we to a national rally that was 1000 miles each way. On the way home the engine got a little bit rough.not much but not as smooth as usual. When we got home I parked it in the shed ,commenting how well it went on the trip. the next week I started it up and promply turned it off,It sounded like it had hammers tied to the crankshaft, I thought it had some of the sleeves (it was sleeved back to standard) come loose. I took the engine out and just heaved it under the bench and fitted another spare engine . Some months later I took the heads off the babbit engine to have a look,the tops of the pistons were all carboned up as well as the head,and the pistons hit this carbon and thats what the noise was. I later I cleaned it off,fitted new straight valves and guides with seals on the inlet and reused this engine for a long time,it is still the smoothest one I have. Lawrie |
