09-24-2013, 02:29 PM | #1 |
Gonna drive every day
Hi, I live in the north east. Is there a good or preferred way to have heat in the cab of my pickup? I'm thinking about a 12 volt battery in a box in the bed and a ceramic heater? Appreciate the help Gino
09-24-2013, 02:39 PM | #2 |
Re: Gonna drive every day
I'd suggest you find an Otwell Health Heater, which replaces the exhaust manifold. I'm very pleased with mine, especially since I live up near Lake Superior!
09-24-2013, 02:49 PM | #3 |
I put a hot water heater in mine. Wife loves it!
09-24-2013, 02:52 PM | #4 |
If it will fit in the cab, a Southwind Heater will do the job. But I don't know if it will fit.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
09-24-2013, 03:04 PM | #5 |
Get an old Autolite manifold heater and do the install. You may already have "the hole" cut thru your firewall. Many do.
09-24-2013, 03:30 PM | #6 |
09-24-2013, 03:33 PM | #7 |
That's what I did.
09-24-2013, 03:48 PM | #8 |
I have used a small coleman catalytic heater and it will definitely keep you warm and with the volume of air leaks in the A, no O2 concerns.
Gene USN |
09-24-2013, 03:53 PM | #9 |
09-24-2013, 03:55 PM | #10 |
Resistance heat from a 12 volt battery will drain the battery very quickly, so it isn't really practical.
09-24-2013, 03:56 PM | #11 |
Do you happen to have a photo of that "hole". I have a hole in the firewall of my '28 roadster and have always wondered what it was for. I looks factory and has always baffled me.
09-24-2013, 04:20 PM | #12 |
Using electricity to generate heat always requires a lot of current. I would go with the hot water heater.
Charlie Stephens |
09-24-2013, 08:04 PM | #13 |
PeteCruz, I don't have a photo yet of my manifold heater door hole, but it is a very LARGE one in the firewall, just above and in-line with your exhaust manifold. About 2-1/4" diam. Up here in the Northeast, I can count on one hand, how many A's I've seen that DON'T have that heater door hole. That's restored ones, "woods finds" and everything car in between. I like the idea of a water heater, but the "A" has such limited room up front for the heater core and a real pain to remove the floorboards sometimes if all the floor screws are in place.
09-24-2013, 08:15 PM | #14 |
Here's one off Google
09-24-2013, 10:12 PM | #15 |
yea hole is about the size of 2 1/4 exhaust tubing could slide thru it...
1929 Model AA - Need long splash aprons! |
09-24-2013, 10:13 PM | #16 |
see the baseball sized hole in the lower firewall section? (yes its whats left of my cab....)
09-26-2013, 07:01 AM | #17 |
Ok, I like the idea of a hot water heater. If anyone can give me some info on the brand of heater and how to do it I'd be grateful, thanks Gino
09-26-2013, 07:40 AM | #18 |
My vote is water heater. If you choose the exhaust manifold heater you'll smell like the engine compartment. Hot water heaters aren't hard to install. Just a little piping and mounting the box inside.
Cowtown A's |
09-26-2013, 08:49 AM | #19 | |
I've also been thinking about just wrapping the muffler and using that heat through a floor grate. That would be even easier as I won't have to run hoses and change the water fittings. |
09-26-2013, 09:13 AM | #20 |
Do you have 12v or 6? If you have 12 there are a number of heater for closed cab farm tractors etc. Here are a couple of options.
http://item.mobileweb.ebay.com/viewi...d=350655925187
09-26-2013, 09:22 AM | #21 |
09-26-2013, 11:57 AM | #22 |
I played around with this problem for a while. I tried a manifold heater, but just couldn't get enough air to flow through it to warm the car. I then looked at restored water heaters, and mocked up a cardboard box of the heater sizes posted in ads, but there just wasn't a decent place to put it in an A.
Then I purchased unit made by Vintage Air that I thought I could mount high up on the inside of the firewall, but that didn't work because the A/C evaporator was in the way. I ended up mounting it under the seat, air blowing forward. I had to cut an opening in the seat riser for a heat outlet, but it isn't seen. Once I got water flow issues worked out, and a thermostat on the engine, the heat output is tremendous. Exactly perfect for my needs. I also knew that using inside air in really cold weather would fog up the windows from the occupants breath, no matter how warm it is inside. SO, I left the manifold heater in place to bring in just enough dry outside air to eliminate that problem. I noticed that there were cold drafts all over (Town Sedan) I fully weatherstripped the 4 doors, sealed real good around the pedals & steering column and the lower cowl areas that are open to the engine compartment. WOW, snug as a bug in a rug! Last edited by kingbee; 09-27-2013 at 02:28 PM. Reason: Spelling |
09-26-2013, 08:18 PM | #23 |
One other note, it's a 12 volt unit. Knowing what I know now, I would convert to 12v in order to have this.
Adequate heat makes driving an A in cold weather an entirely different experience..... |
09-27-2013, 05:49 AM | #24 |
So technically you could say that you have heated seats!
03-08-2019, 11:21 PM | #25 |
I have a new H/W heater, the 7" X 7" and the water pipe with pickup to force HW to the heater. Having a fit trying to figure best way to mount & plumb this guy given gas valve and choke rod. Help??
03-09-2019, 02:00 AM | #26 |
03-09-2019, 09:13 AM | #27 |
Rusty Homestead, That's a nice heater for Fla. My question is how to hook the heater output to the feedthrough in the firewall. The ones that I have seen just leave the space between the manifold heater and the firewall. Some heat must be lost between the two which is some cases looks like a gap of 3/8" or so . Jack
03-09-2019, 09:54 AM | #28 |
If your handy and concerned about size try a power steering cooler.use a flapper and a duct to operate it with forced air or rig a computer cooling fan.. |
03-09-2019, 10:04 AM | #29 |
03-09-2019, 12:05 PM | #30 |
03-09-2019, 01:56 PM | #31 |
I like railcar's oil cooler idea, I would come off the engine water outlet with 3/8" steel brake line and go just above manifold then under cab, fasten 3/8" ball valve under floor board with the handle inside the floor board then a steel return line to water inlet side of engine, unit will set under seat.
03-09-2019, 07:33 PM | #32 |
Not sure but if I kept a couple of those around my wife just might generate a lot of heat, plus she would have my guts for garters
