Old 03-23-2021, 09:28 AM   #1
cluck
cluck's Avatar
Default zenith 2 carburetor
could the zenith 2 carburetor been an original carburetor on a 1930 model-A ford?
cluck
cluck is offline   Reply With Quote
Old 03-23-2021, 09:43 AM   #2
JayJay
Default Re: zenith 2 carburetor
cluck
Cluck - in short, yes. The Zenith Model A -1, -2 and -3 didn't represent succeeding generations of carburetor, they indicated the manufacturer. -1 were manufactured by Zenith, -2 were manufactured by Holley, and -3 were manufactured by Ford. I don't think the -3 version is too common. There are many references that discuss the Zenith carb, you can look here for an overview.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 03-23-2021, 09:45 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
The designations Zenith 1, Zenith 2 & Zenith 3 indicate the company that made the carburetor. Zenith 1 is Zenith, Zenith 2 is Holley and Zenith 3 is Ford.
Carburetors with no designation can be Zenith or Holley. It is common for no designation Holley carburetors to have an "H" in the castings.
The OEM carburetor on your 1930 car could have been a Zenith 2.
Bob Bidonde
Old 03-24-2021, 02:34 PM   #4
Ed in Maine
Hello Bob, since we are on the subject of carburetors, I have seen your comments about the secondary well and how it may be restricting flow from the Compensator Jet. I have been rebuilding carbs for my club and would like to know what the symptom would be if there is a problem? I have a bunch of Secondary Wells and they all appear to be the same. The other day I took an awl and in going through the open Compensator Jet, I scratched the side of the well. I was amazed at how high up the scratch is and it is in the large diameter section of the well. I believe you are correct that it is possible to have a restriction through the Compensator Jet. I was thinking of grinding a slot down the side of the Secondary Well to the entrance hole at the bottom. Does this sound like a good idea? Sorry to be so windy, Ed
Ed in Maine is offline   Reply With Quote
Old 03-24-2021, 03:23 PM   #5
700rpm
700rpm's Avatar
I had a restored Zenith-3 on my Tudor. I went to a MAFCA National meet, and someone stole it off my car in the parking lot, and replaced it! with an unrestored Z-2. I couldn’t figure out why my car was running so rough until I opened the hood. >:-(
Ray Horton, Portland, OR
Old 03-24-2021, 05:05 PM   #6
Brentwood Bob
Ed, you are correct. There are several different secondary well designs. The later wells, I believe, are relieved.
Brentwood Bob is offline   Reply With Quote
Old 03-24-2021, 08:55 PM   #7
shew01
shew01's Avatar
Originally Posted by 700rpm View Post
I had a restored Zentith-3 on my Tudor. I went to a MAFCA National meet, and someone stole it off my car in the parking lot, and replaced it! with an unrestored Z-2. I couldn’t figure out why my car was running so rough until I opened the hood. >:-(
Wow. That’s amazing. What some folks will do...
shew01 is offline   Reply With Quote
Old 03-24-2021, 09:40 PM   #8
Benson
Benson's Avatar
I have seen 2 or 3 carbs where someone took a Zenith 2 used a Dremel to make it look like a Zenith 3
and passed it off on Ebay as a Zenith 3.
Benson is offline   Reply With Quote
Old 03-26-2021, 09:05 AM   #9
cluck
cluck's Avatar
Thanks very much for the info.123 are the mags.
Old 03-26-2021, 09:10 AM   #10
cluck
cluck's Avatar
good to know a zenith 2 could have been on my car. and 1,2,3 are the mugs-cluck
Old 03-27-2021, 12:22 AM   #11
redmodelt
redmodelt's Avatar
"and 1,2,3 are the mugs" Local slang? What is mugs?
Old 03-27-2021, 01:52 PM   #12
JayJay
Typo for "mfgs"? Kinda same question when he referred to "mags" in the post immediately preceding.
My fingers aren't as nimble as they used to be.
JayJay
JayJay
Old 03-28-2021, 09:37 AM   #13
cluck
cluck's Avatar
thanks for the info on my Zenith 2 carb. Typo for mugs and mags should have been mfg.
Old 03-28-2021, 09:46 AM   #14
redmodelt
redmodelt's Avatar
Thanks! Mfg didn't even come to mind, I was thinking that I needed to add a new word to my vocabulary.
