Old 10-11-2018, 06:37 PM   #1
12secvx
Default Late 31 oil pump shield?
I have read every thead known and the same question gets asked. Can 1/8” be trimmed off the bottom of a oil pump shield to fit in a older pan? But it never get answered or does it just not make sense to do so because there will be not added benifit? I understand the pans had lowered dipper trays that the shield came with. Thanks Ben
12secvx is offline   Reply With Quote
Old 12-12-2020, 05:27 PM   #2
duke36
Default Re: Late 31 oil pump shield?
Interesting question. Anyone done the trimming successfully ? Would the extra 1/8" compromise flow because the dipper tray is not lowered? FORD must have had some reason not to refit prior (higher) trays.
duke36 is offline   Reply With Quote
Old 12-12-2020, 08:04 PM   #3
denis4x4
denis4x4's Avatar
Send me $10 for priority mail and I’ll send you one to try!
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-13-2020, 06:45 PM   #4
duke36
Not sure what this is in reference to. Having examined a repop shield, it looks like it can trimmed at the bottom edge but not sure there would be adverse oil pumping or volume issues with the non lowered tray? Could the oil pump or rod dippers oil pickup operations be affected ?
Old 12-13-2020, 10:12 PM   #5
denis4x4
denis4x4's Avatar
Mine is an original that I removed from a B engine
Old 12-14-2020, 06:20 AM   #6
DBSHELTON
I bought several from Model A Medic that fits the earlier trays. I would assume it has been trimmed. They fit fine.
DBSHELTON is offline   Reply With Quote
Old 12-14-2020, 11:47 AM   #7
duke36
We found a repo shield in a spare parts box (not sure of the vendor) that measures 3 1/4" from the bottom to the top mount flange plate. The photo is slightly distorted. How does this compare to an original, if anyone has one? Model A medic lists one that is trimmed 1/8" to fit older trays.
