Old 11-01-2015, 07:04 PM   #1
38FordTruck
Default 1938 Truck Cable to Hydraulic brakes
Rebuilding my 3ton '38 and can get hold of '39 hydraulics. Using both front spindles & hubs from '39 can swap to front axle )38 cable brakes are larger diameter hub/spindle backing).
The '38 rear axle backing plate size to axle is 7" can anyone advise on the '39 hydraulic hub / backing being 7" and will fit and with same axle??
Issue is I am in Tasmania (smaller island south of Australia mainland) - parts are 1895 Kms / 1177 miles away on a station on the "mainland".
Any foreseen issues if the sizes fit.
Currently have everything stripped ready for the "big" rebuild.
38FordTruck is offline   Reply With Quote
Old 11-01-2015, 07:22 PM   #2
JSeery
JSeery's Avatar
Default Re: 1938 Truck Cable to Hydraulic brakes
We know where Tasmania is, we do watch cartoons you know! LOL
Old 11-02-2015, 10:07 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Oh yeah! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-02-2015, 11:24 AM   #4
JSeery
JSeery's Avatar
Sorry we're messing around on your thread, but maybe if we keep it near the front someone will know the answer to your question!
Old 11-02-2015, 12:41 PM   #5
flatheadmurre
flatheadmurre's Avatar
Not sure what ratio your rear is or if your gonna use it for hauling rock...
But with a major rebuild of the rear i would start by thinking about if it has a useable ratio.
If not i swap in a complete axle from something more drivable...but its just me.
