Old 11-29-2023, 11:03 AM   #1
al's28/33
al's28/33's Avatar
Default removing hubs to replace bearings
thanks for all advice and support!
first time removing rear hubs to inspect possible worn out wheel bearings, do I need to back off the brake adjustment to free up all the pads inside ?
the online videos do not all detail this very clearly, thanks.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 11-29-2023, 11:11 AM   #2
Will N
Will N's Avatar
Default Re: removing hubs to replace bearings
Sometimes yes, sometimes no. Depends on how tight the shoes are adjusted to begin with. It couldn't hurt to back off the adjustment. But the bigger issue you'll face is getting the hub off the axle. Do you have a hub puller? If that hub hasn't been off in a while, it could be stuck pretty good.
Will N is offline   Reply With Quote
Old 11-29-2023, 11:17 AM   #3
JayJay
Yes, back off the service brake by backing out the adjustment screw. But be prepared for the hubs to be really stuck on the axles (it's a taper fit), you'll need to use a puller of some sort. A bit pricey, but the Mitchell puller is probably the best out there. After you get the hub broken from the axle you may find it hanging up on the e-brake, you can manually move the e-brake lever backwards to allow you to pull the drum off.
Don't forget that you'll likely want to replace the inner rear seal and possibly the felt seal at the outside.
See PM from me to you.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
