05-11-2022, 04:49 PM | #1 |
Hole in intake manifold - on purpose!
Hi all - Any guesses as to why someone would install a fitting onto the intake manifold that would allow you to unscrew part of it to open a hole in the manifold? I'm trying to get a friend's 1928 roadster pickup to start. It cranks well but never turned over until I removed the top of the fitting. It started once and ran very fitfully for about 10 seconds, then back to not starting.
There are other issues with it, but I'm trying to understand the intake manifold hole. Thanks in advance. |
05-11-2022, 04:54 PM | #2 |
Re: Hole in intake manifold - on purpose!
Picture??
The Master Cylinder Enjoying life at the beach in SoCal... |
05-11-2022, 05:04 PM | #3 |
Sounds like the vacuum port for the wipers
05-11-2022, 05:05 PM | #4 |
Hmmm. I might be but there are no wipers connected. Sorry, I didn't take a pic.
05-11-2022, 05:47 PM | #5 |
If you have a steel tube running under the very right side of the gas tank, or even the fittings designed to hold that tube, it came with a vacuum wiper...
05-11-2022, 06:46 PM | #6 |
05-11-2022, 06:57 PM | #7 |
Could be it was put there to ad one of those ole wolf whistles.
05-11-2022, 08:22 PM | #8 |
Or it could be that a manifold off a car with a vacuum windshield wiper was put on this car that has an electric windshield wiper.
To start your friend's car, I assume you have checked all the usual stuff. Spark, timing, compression, fuel, etc. Opening the hole in the manifold would have nothing to do with the car starting but would make it run lean and not idle.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-11-2022 at 08:27 PM. |
05-11-2022, 09:25 PM | #9 |
i have had other car engines that the intake manifold has had a fitting installed for priming.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
05-11-2022, 11:51 PM | #10 |
28's had no vacuum port in the intake manifold.
29 and later had a vacuum port in the manifold which has a round boss around the hole. Many of the manifolds without a hole in the manifold were drilled later by owners or mechanics and would not have the round boss around the hole. Richard Anaheim CA |
05-12-2022, 03:48 PM | #11 |
Thanks everyone. I'll be back at it on Sunday (after rebuilding the carb) and will see how it goes. There's no hint of a steel tube for vacuum purposes. Will keep playing with it!
