Old 11-21-2020, 03:53 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Radiator filter - where purchase?
I need a Gano radiator filter for my Model A.
Gano may have gone out of business?
Does anyone have an extra one for sale or can you recommend another brand?
Thank you,
Neil
[email protected]
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 11-21-2020, 03:57 PM   #2
Default Re: Radiator filter - where purchase?
Does anyone have a picture of one installed?
Also, which way does the water flow?
Does the water flow from the cylinder head up into the radiator or from the radiator down into the head?
If the Gano is installed in the upper radiator hose, will it keep debris from entering my new radiator?
Old 11-21-2020, 04:21 PM   #3
SoCal_Alden
SoCal_Alden's Avatar
Neil, The water flows from the cylinder head into the radiator. https://ganofilters.com/
Last edited by SoCal_Alden; 11-21-2020 at 04:24 PM. Reason: added GanoFilters website
SoCal_Alden is offline   Reply With Quote
Old 11-21-2020, 04:43 PM   #4
Alden,
Thank you for the info.
I left them a voicemail.
I assume you purchased the clear one?
Is the debris actually trapped or would it fall back into the head if the filter was removed?
Regards, Neil
Old 11-21-2020, 04:57 PM   #5
Bob C
Looks like you can order them on their web site.
https://ganofilters.com/ecommerce/in...e=products_all
Old 11-21-2020, 06:00 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Neil, try Restoration Supply Co. in Escondido, CA https://restorationstuff.com
Gano and Restoration Supply Co. are the same company, have same address.
Old 11-21-2020, 06:20 PM   #7
Chris Haynes
Chris Haynes's Avatar
I fill my cooling system with the RUST911 mixture. Drove the car for a while. Let it set overnight. Drained it, it came out black. Repeated the process twice more. On the third time the RUST911 mixture came out clear. The block and radiator were both clean as could be. Any and all rust particles were dissolved and gone. Refill with coolant and rust inhibitor and you will have no need for a filter.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
