Old 11-01-2019, 05:10 PM   #1
barnnone51
Default Crankshaft Pulley Removal
Thanks Ford Barn and Ya"ll For the Search section for doing repair on
our Model A . I needed to change the Crankshaft pulley and I did a little
Search and saw were it was said to put your wrench on the drivers side
frame and rock the starter, bada bing nut came right off.It was a beautiful
thing no fuss no muss. It was a good thing that I had to change it because
found a sizeable crack on the fan.Well Thanks again now put it back together
and hit the road again...
barnnone51 is offline   Reply With Quote
Old 11-01-2019, 10:31 PM   #2
30 Closed Cab PU
Default Re: Crankshaft Pulley Removal
Glad you found the crack before the blade let loose. Hope you replaced it with the 2 blade 1 piece aluminum fan.
30 Closed Cab PU is offline   Reply With Quote
Old 11-02-2019, 07:47 AM   #3
barnnone51
Yes brand new two blade. Wife says weld it. I said sure give me your credit card..
