09-19-2019, 05:29 PM | #1 |
Clutch finger Adjustment
I am having a problem adjusting the fingers on a new clutch. I have made
a nice tool for the proper height of the finger the problem after adjusting and it is nuts on I go to stake and it all moves. I guess I am not a staker.. By the way I am using locktite..Would using nylock nuts be ok? It seems that would be the answer verses stake.. Any help would be Great.: |
09-19-2019, 05:48 PM | #2 |
Re: Clutch finger Adjustment
I've not used them, but, I think the nylocks are a good idea.
09-19-2019, 06:21 PM | #3 |
Pressure plate gets pretty hot. Nylocks might be risky. Developing a staking technique would be the safest.
09-19-2019, 09:59 PM | #4 |
I believe the nylock will take up to 250 degrees. Wonder if the pressure plater gets
to that level. Of course it is something to consider .. |
09-20-2019, 03:15 PM | #5 |
I wouldn't think that plate could get warm enough to boil water.
09-20-2019, 05:28 PM | #6 |
that Tom Wesenberg said he used locknuts so the light went on! Not sure If he used nylocks but said locknuts. So I found some today and they are MM which that tells me this pressure plate is from afar.. Which is ok as long it works.. I am lucky no body on the chassis so easy Peasy to remove motor and make the install and fresh up the paint. Thanks for the response from you fella's |
09-20-2019, 10:17 PM | #7 |
I used locknuts and staked them once I was happy with the adjustment as there was very little thread engagement on the plastic part. I ended up with a .625" finger adjustment
