Old 12-17-2018, 06:06 PM   #1
barnnone51
Default Little Help with the Ignation wiring
I am building a Tudor 1931 with a mix of parts. I bought a rolling chassis and
motor. I am trying to fire her up and check for oil leaks and general running.
I have a question on the Wire diagram .From the junction box to the coil
should be hooked to the --negative side? from there Positive side to Ignition switch.Other side to the Dizzy. included in the parts was a Ballast Resistor and what I have read with a 12 volt system you need a ballast Resistor in that
case where should it be installed if in fact that I need one. Thanks for your
help!!
barnnone51 is offline   Reply With Quote
Old 12-17-2018, 06:57 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Little Help with the Ignation wiring
info
www.whidbeymodelaclub.com
Old 12-17-2018, 09:32 PM   #3
Jim/GA
Jim/GA's Avatar
Are you planning to wire the car with 6 volts or 12 volts?
Positive ground (as original) or negative ground?
Answer these 2 questions and I can help you wire it up correctly.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 12-17-2018, 10:33 PM   #4
barnnone51
I am going to run 12 volts and positive ground.
Old 12-17-2018, 11:06 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
.From the junction box to the coil should be hooked to the --negative side? from there Positive side to Ignition switch.Other side to the Dizzy. included in the parts was a Ballast Resistor and what I have read with a 12 volt system you need a ballast Resistor in that case where should it be installed if in fact that I need one. Thanks for your help!!
Notice the drawing does not show positive or negative. It only show a ground.
So since you are using 12 volt (voltage makes no difference) negative ground lets follow the drawing.
Positive of the battery goes to the starter connection and on to the #5 of the junction box.
The #5 terminal goes to the ammeter and back to the terminal labeled 8 on the junction box.
From #8 the positive goes to the + or alt marked on the coil.
Depending on the coil the other side (neg) goes to the switch. I say depending because you can get internal ballast coil or external ballast coil.
Out of the switch to lower plate then upper plate, the points and then to ground and the negative of the battery.
Old 12-18-2018, 12:06 AM   #6
Jim/GA
Jim/GA's Avatar
If you are going to run 12 volts with a stock coil (or a coil designed for 6 volts) then, yes, you need to use a ballast resistor. The most common place to put it is in the wire between the terminal box and the coil.
Because you are running positive ground, the positive post of the coil must connect to the wire that runs to the key switch and then down to the points. That is the important detail. The points provide the ground to the coil, so positive ground means connect wire from points to positive coil post. Simple.
Jim Cannon
Old 12-18-2018, 08:07 AM   #7
barnnone51
Thanks fellas for all your input very helpful. There was one more thing that I noticed
was that they had a capacitor hooked on junction box the side going to the coil.
Old 12-18-2018, 12:14 PM   #8
Badpuppy
No reason for a cap at the JB. Toss it.
Badpuppy is offline   Reply With Quote
Old 12-18-2018, 01:22 PM   #9
Mike V. Florida
It is possible that the condenser was relocated from the distributor to the firewall. Be sure you have one somewhere, better in the distributor.
Old 12-18-2018, 01:32 PM   #10
Charlie Stephens
I would strongly recommend 12 volts NEGATIVE ground so you could run modern electronics when you want to. Sometimes it pays to be like everyone else.
Charlie Stephens
Old 12-18-2018, 03:28 PM   #11
barnnone51
Charlie once I put the body back on will change over to negative ground. Now just
trying to crank her up and put around the ranch..
