Old 11-27-2016, 01:57 PM   #1
RockHillWill
RockHillWill's Avatar
Default Wooden egg crate buck for aluminum front fender for a '30-'31 Model A
I just completed the drawings for this Model A fender buck, and am posting while it is all fresh in my mind. This is not the only way, just one way. I like making drawings, so this is the approach that I have taken, and from my limited experience, I like the fact that I can use it as a hammer form buck if I need to. In some previous bucks, I was too liberal in making the buck ribs be vertical, leaving too much sanding to fit the actual contours. That also made it harder to hold up under some of the 'angled' hammer blows. I learned the West System glue usage from Jim Hery and the 3D scanning was done by Scott White at the last Redneck Roundup.
This the .IGES file that was sent to me by Scott White after he 'worked over' the point cloud from the 3D scan taken in the shop.
I saved that file as a parts file in SolidWorks.
One of the earliest steps was to establish a base and back bone that could be cut out of the available 60" x 60" Baltic birch plywood. Then a 'plane' surface was determined at the highest point of the contour and using the cut surface of the 3D scan the back bone was drawn to match that contour, and the cross web locations were cut in place.
By establishing a working plane at one side of the web slots, and using the edge of the fender as determined by the cutting plane, a cross web contour was established then extruded to the thickness of the plywood. By using the 'convert entities / intersection curve' command the dark line along the contour is established at the exact location of the fender skin.
This is the combination support and contour web from the above cross section.
Pre-assembly holes were added to the SolidWorks drawing of the base to locate the support webs and the component assembly was started.
One of the last cross ribs about to be inserted on to the back bone.
Pre- assembly of the drawing components almost completed.
Components in place. The notches at the side are for the edge ribbing. Where the edging looks to be protruding shows where the edging will be bent to the fender contour at the assembly gluing process.
Individual drawings are then made and further saved as a .dxf file for use at the water jet place. Minimal dimensions are required only to allow the water jet operator to check the scale before cutting.
For these larger projects, I assemble the components into a 60" x 60" plywood panel for cutting at the same time.
This is the drawing, in .dxf format that will be sent to the water jet guy for cutting. In both the above and below photos there are components that are for a Bugatti headlight buck project, as I could take advantage of combining projects.
Here is a picture of the completed buck without the fender in place.
This picture shows the fender superimposed on the buck. The parts that show above the fender scan are the areas that will need to be 'custom' sanded before being able to use the buck. The red outer edging component is made longer than the fender to account for the material needed to include the wire edging prior to forming the fender edge bead typical of the Model A's.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 11-27-2016, 02:36 PM   #2
DaWizard
Send a message via AIM to DaWizard
Default Re: Wooden egg crate front fender buck for a '30-'31 Model A
Oh Will, very nicely done. Since all my drawing/drafting background was done with paper and pencil I am envious of those working in CAD now. Seems I was born way to early to take advantage of the new software.
What scale will this be 3D printed in?
Will you make a 3D printing and assemble the finished car?
How many body styles will you make?
Are they going to be for sale?
Will you make it for the 28/29?
Can I put in an order for a '28 Tudor?
Damn, I am so jealous because I have found that to learn new things my brain needs to lose old knowledge and I can't afford to do that.
Braincell challenged J.C.
New owner of '28 Tudor
Previously owned;
'30 Sport Coupe
'28 left brake ccPickup
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
'42 Super Deluxe 4door Sedan
"If it don't fit, get a bigger hammer.
If it breaks...... ya needed a new one anyway!!"
Doing a good job here is like wetting your pants in a dark suit.
It gives you a warm feeling, but nobody notices.
Never pass up a bathroom
Never neglect an erection
Never trust a fart
DaWizard is offline   Reply With Quote
Old 11-27-2016, 03:12 PM   #3
Kevin in NJ
So you are creating one for each of the 2 styles of fenders?
You do know there are 2 shapes to the 31 style fender.
One has the crease stop as it flattens out and the back section is sort of flat. The other the crease goes further down and is more rounded.
I point this out cause I brought it up a few years ago and some of the big names in the A judging standards. They even had a car that had one of each type and it is a car that is known to be 100% original.
Old 11-27-2016, 04:57 PM   #4
todd3131
todd3131's Avatar
Was your plan to use a CNC table to make the buck? I have one and could make it for you the only issue for you is all of the cuts will be at 90 degrees.
todd3131 is offline   Reply With Quote
Old 11-27-2016, 06:57 PM   #5
RockHillWill
This buck was made purely to practice my panel fabrications in aluminum and to practice gas welding aluminum for an upcoming Bugatti project. The Bugatti bucks that I have built are in Tennessee, and this will give me a project in my shop to sharpen my skills. I had originally intended to help only on the frame and mechanicals portions of the Bugatti, but a recent acquisition of a particular wheeling machine has heightened my interest in aiding in the panel fabrication as I have learned a few new ideas and have gained a new respect for the capabilities of the English wheel.
The fender that was used for the scanning was one being used on a fine joint project, so it is a full scale fender. Aside from the extended bead design, I personally feel that the differences in the fender 'crease' is not from a design change but is due to die/stamping wear throughout production, but is of no concern on this project.
Old 11-27-2016, 07:02 PM   #6
DaWizard
So you are saying you will NOT toss this into a 3D printer and make a model car of it?
Seems a shame to put all that time into it to not make at least one small one from it. *sighs*
Previously owned;
'30 Sport Coupe
'31 SW Town Sedan
'28 AA Stake Bed
'30 Cabriolet
Never trust a fart
Old 11-27-2016, 09:34 PM   #7
Kevin in NJ
It is not just a crease change, it has to be a different design.
The curve from the bead to the crease is carried much further down towards the running board. The crown is much higher then the other type of fender.
That can not be a worn out die, but a different design. It really stands out when you have the 2 fenders next to each other. There is no way there would be a loss on the order of like a 1/4" on a crown (I have never measured it, but it is considerable from the die stamping stand point and wear).
Old 11-28-2016, 07:57 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I BARELY have the skills to change a FUEL VALVE handle???
Bill Dense
"THE ASSISTANT GURU OF STUFF"
Old 11-28-2016, 08:10 AM   #9
RockHillWill
Thanks, Kevin. I have not been exposed to that information before, but as I mentioned, this effort was done to provide a practice 'project' before starting on the Bugatti body build, rather than to duplicate a perfect Model A fender.
If the fender build goes successfully, I have a set of right and left side Kirksite bucks that I acquired from a real old timer from Sterling Heights that worked at Ford. They are for forming the lip in the fender prior to installing a fender well. I will try that next.
P.S. What type of information was presented to authenticate the fact that it was 100% original ? It could have 'original' 1935 fenders and still be 'original'. That has always been a curiosity for me, how someone who was born 30 years after the car was assembled can authenticate the condition as 'original'. I'm not trying to be confrontational, just making an observation. Might be the same dies, but not the same operator?
Old 12-05-2016, 10:26 AM   #10
RockHillWill
I just brought home the components for the fender build. Am waiting a day or two for the wood to dry out.
Old 12-06-2016, 04:52 AM   #11
Rex_A_Lott
What material are you going to use for the fender? How many pieces? We are waiting for the pictures...
Rex_A_Lott is offline   Reply With Quote
Old 12-06-2016, 08:39 AM   #12
RockHillWill
Hey, Barry. I will be using the 3003 aluminum that we used at Peters class and on the Bugatti build. You are welcome to help...
Old 12-06-2016, 12:39 PM   #13
Rex_A_Lott
If you don't have it finished by the first of the year, I'd like to get up there. My plate is pretty full for December. Good luck and happy hammering!
Old 12-09-2016, 07:50 AM   #14
RockHillWill
Barry, I imagine we will still be working on this fender at the upcoming Redneck Roundup. The Roundup looks like it is shaping up to be an 'aluminum' event. Many bucks for the Bugatti project, aluminum welding, etc. All in addition to several sheet metal 'projects'. I have a Fordor door to skin, a fender to add in a well, etc. There will be at least four wheeling machines, the two large ones you saw at the Peter Tommasini class and at least two of Peters cast iron machines. I have been getting lots of feedback about how fast these machines are. You used them at the class.
Old 12-12-2016, 11:07 AM   #15
RockHillWill
Some progress to report. Have gotten started on assembly of the pieces. The base had the holes installed at the water jet place to screw the four support ribs in place on the base. I outlined the positions on the top side with a pencil, pre-assembled those four ribs, and glued them to the top side. Then, the next day, I turned the buck on it's side and installed the wood screws, then glued the other ribs in place. Installation of the side pieces is next. The 'articles' in place on the buck are to position two ribs that did not hold there shape very close because of weight distribution issues.
Old 12-12-2016, 07:22 PM   #16
RockHillWill
Here are a few more from today, Installed two nose pieces and fit, formed and glued the outer side contour rail.
Old 12-13-2016, 07:06 AM   #17
Rex_A_Lott
Looking good. I noticed you let the speedster back into the shop...
I dont know if you would need a buck, or just a paper pattern, but start thinking about what it would take to make a gas tank. I'm thinking the neck would be the hardest part.
Old 12-15-2016, 07:57 PM   #18
RockHillWill
Just about finished with the buck itself. The tapered edges of the upright rib supports have to be sanded, but all the pieces are in place and the glue has dried. I still have to located the long character line down the center, but I have located the position, I just have to grind the ribs to the correct depth and contour. Just took a few minutes to practice using the wheeling machine and a borrowed machine to 'get my hands dirty, making a couple of test panels.
Old 12-18-2016, 08:29 AM   #19
RockHillWill
Had a chance yesterday to put a VERY NICE original fender on the buck, and it fit as good as expected. I still have to trim the sharp corners on three of the vertical ribs to get the fender down about another 1/8", but overall I am happy with the fit.
Old 12-18-2016, 09:45 AM   #20
Tony Hillyard
Tony Hillyard's Avatar
That is really very impressive. Please keep us up-dated with the progress.
Tony Hillyard is offline   Reply With Quote
