Old 07-20-2023, 10:54 PM   #1
BoxCar Tom
BoxCar Tom's Avatar
Default Rubber cement removal?
What's the best way to remove rubber cement from the 32 cowl vent channel?
Yup fat gasket!
Anyone know where to get the correct thickness gasket? Thanks,,,
BoxCar Tom is offline   Reply With Quote
Old 07-21-2023, 12:34 AM   #2
petehoovie
petehoovie's Avatar
Default Re: Rubber cement removal?
Yup fat gasket!
See comparisons at this link > https://prudentreviews.com/goo-gone-vs-goof-off/
Old 07-21-2023, 06:42 AM   #3
TerryS
TerryS's Avatar
My experience with Goof Off pro strength on a side panel of a pontoon boat. I removed registration stickers from a dark grey panel and it considerably lightened the paint color. It may be good in a vent channel where the finish is not on an exposed surface that will pick up the reflection of the sun?
I had to cover my mistake with a vinyl stripping.
Terry S
TerryS is offline   Reply With Quote
Old 07-21-2023, 10:47 AM   #4
petehoovie
petehoovie's Avatar
Terry S
Old 07-21-2023, 11:48 AM   #5
Tim Ayers
I wonder if a heat gun would help soften it enough to pull off.
Old 07-21-2023, 12:38 PM   #6
Flathead Fever
Flathead Fever's Avatar
If you don't want to damage the paint, I would not use any kind of chemical. I would just scrap the thick stuff out of there with a narrow plastic putty knife and glue the gasket over the thin stuff that won't come off. If you don't care about the paint, a wire wheel will clean it down to the bare metal. I have some of those repro thick spongy gaskets that make the vent stick up above the cowl. I thought about just making my own gaskets out of something thinner.
Old 07-21-2023, 01:15 PM   #7
Willit Stop
Willit Stop's Avatar
I removed some door seal rubbers from a truck that had a 30 year old paint job with wax and silicone remover. It's a solvent that weakens / dissolves the adhesive enough to make it gooey. Then I sprinkled sawdust on the weakened adhesive and rubbed it with a rag. The semi-dissolved adhesive would stick more to the sawdust than the paint and would roll up into a ball. It took quite a while but it did work and did not harm the paint.
Willit Stop is offline   Reply With Quote
Old 07-21-2023, 05:18 PM   #8
19Fordy
19Fordy's Avatar
Here's some good info.
https://www.bing.com/search?q=will+v...ANAB01&PC=HCTS
Old 07-21-2023, 10:51 PM   #9
fordor41
fordor41's Avatar
autozone sells adhesive remover in a spray can. softens adhesive but does not effect paint.
fordor41 is offline   Reply With Quote
Old 07-21-2023, 11:02 PM   #10
petehoovie
petehoovie's Avatar
Old 07-21-2023, 11:09 PM   #11
johndee138
johndee138's Avatar
Why glue the gasket in anyway? Where's it gonna go? It can't get away. After my repaint, I just laid it in the channel. Cowl vent door closes on it and it hasn't ever moved when the vent is open. any water runs out the drain as designed. No glue goobing up my paint either.
johndee138 is offline   Reply With Quote
Old 07-21-2023, 11:45 PM   #12
rich b
rich b's Avatar
Wonder how one of the rubber eraser wheels would work. Worked to remove stickers and their adhesive in the truck shop.
Old 07-22-2023, 05:59 AM   #13
corvette8n
corvette8n's Avatar
Be careful with the pro strength goof off, I’ve had it remove paint.
Old 07-22-2023, 05:06 PM   #14
BoxCar Tom
BoxCar Tom's Avatar
Thanks for all the good suggestions, the car is already painted so at least now I know what to avoid. Thanks again.
