Old 08-03-2022, 03:29 PM   #1
Ford coupe
Unhappy 79 granada engine noise
79 granada with engine rebuild new bearings rings and lifters TWICE ..Engine startedout with what sounded like lifters so thinking i may have got bad ones replaced those to no avail. it now sounds like no oil up top but after removing top pan i find lots of oil at an idle and oil pressure is very good.. Now the only thing i did not replace was the cam and bearings as they seemed as new..It is not rod or mains i am sure but what sounded like a slight lifter noise when started is getting worse and i can now hear it in the car so getting a bit scaryIt is the 4.1 in line 6 by the way..So i will sign off and hope some specialist sees this and gets back to me...Thanks in advance..
Ford coupe is offline   Reply With Quote
Old 08-03-2022, 04:41 PM   #2
KULTULZ
KULTULZ's Avatar
Arrow Re: 79 granada engine noise
Engine started out with what sounded like lifters so thinking i may have got bad ones replaced those to no avail. it now sounds like no oil up top but after removing top pan i find lots of oil at an idle and oil pressure is very good.. Now the only thing i did not replace was the cam and bearings as they seemed as new..
Did you check lifter lash at re-assembly? Better yet, did you keep the push-rods in proper sequence when removed?
Valve lash is determined by push-rod length in this hydraulic valve-train design. There is a STD length push-rod and 0.20 O/S and U/S lengths.
Varying length lifters and push-rods were also used in this series.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 08-03-2022, 09:37 PM   #3
fordor41
fordor41's Avatar
Default Re: 79 granada engine noise
That's why I always keep lifter,push rods and rockers in order that they were removed from the engine
fordor41 is offline   Reply With Quote
Old 08-04-2022, 12:21 PM   #4
Ford coupe
All push rods were meticulusly put back in place where removed from..timing chain well within specks new tappet rod and tappets seem tight seems like lots of oil up top so a head scratcher..Also head was donewith new guides seals and valves were needed so???
Old 08-04-2022, 08:12 PM   #5
KULTULZ
KULTULZ's Avatar
Originally Posted by Ford coupe View Post
All push rods were meticulusly put back in place where removed from ..timing chain well within specks new tappet rod and tappets seem tight seems like lots of oil up top so a head scratcher.
Also head was done with new guides seals and valves were needed so???
The push-rods (STD-U/S-O/S) are how the final valve lash is arrived at in this type of hydraulic valve-train. Re-use and same position placement of the take-out push-rods has no bearing on arriving at proper valve lash with new tappets and the head re-done.
It is one of three things (IMO), incorrect valve lash, insufficient oil pressure and/or a bad camshaft.
We went through all of this a few months ago didn't we?
Old 08-04-2022, 10:38 PM   #6
Ford coupe
Yes we did go through this but before he installed new lifters as he and i thought he had got a bad set of chinese lifters ..But changing them did not help...I really dont see any way of adjusting valve lash other than the lengh of the push rod so?? Might have to look at the camshaft...Thanks so much I feel like a nuisance...Harry
Old 08-05-2022, 05:05 AM   #7
Stiggy
With the tappet cover off and the engine at idle, see if the push rods are rotating..
Stiggy is offline   Reply With Quote
Old 08-05-2022, 06:21 AM   #8
ponymare
Flat tappet cam. did you use the zink additive mixed with the oil on start up and run at proper speed for a length of time? New lifters on an old cam can wipe out the cam lobes, and if it's getting louder, that sounds like the problem.
ponymare is offline   Reply With Quote
Old 08-05-2022, 08:06 AM   #9
KULTULZ
KULTULZ's Avatar
Post Re: 79 granada engine noise
WELL, NO.1 you are not a nuisance. You want to know something and you asked.
The only thing I know to do at this point is to verify cam lobe lift and lash.
How did he rebuild an engine without a manual?
Old 08-05-2022, 09:11 AM   #10
KULTULZ
KULTULZ's Avatar
- HYD LIFTER PRELOAD EXPLAINED -
https://www.enginebuildermag.com/201...ifter-preload/
Old 08-06-2022, 07:13 AM   #11
Ford coupe
ALL INFO WAS FROM A HAYNES MANUAL AND THE MECHANICAL EXPERIRENCE OVER THE YEARS..tHE MANUAL WAS FOR THAT CAR..
Old 08-06-2022, 08:41 AM   #12
bobss396
bobss396's Avatar
It may be time to drain the oil and cut open the oil filter. Run a magnet through the oil and see what sticks to it. Read up on how to dissect an oil filter and what to look for.
bobss396 is offline   Reply With Quote
Old 08-06-2022, 08:58 AM   #13
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 79 granada engine noise
That's fine. There was no section on setting up the valve-train after the rebuild?
Old 08-06-2022, 08:56 PM   #14
Ford coupe
Can anyone tell me the correct valve lash for this engie as i can not find it anywhere???
Old 08-06-2022, 09:00 PM   #15
KULTULZ
KULTULZ's Avatar
Red face Re: 79 granada engine noise
The only thing I could do is copy the pages from the WSM and mail them to you as my copier has a case of no-go.
