Old 09-03-2017, 07:42 AM   #1
Roadster5040
Roadster5040's Avatar
Default 33 hub cap install.
Question regarding installation of hub caps on 33 coupe. Any tricks to this do not want to go on easily. Although I did have wheels powder coated could be part of issue paint seems heavier that original.
Everyone have a good Labor Day.
Roadster5040 is offline   Reply With Quote
Old 09-03-2017, 08:46 AM   #2
DavidG
DavidG's Avatar
Default Re: 33 hub cap install.
They should go on easily, so it is likely excess paint is constricting the openings for the caps in the wheels. Powder coating usually leaves a much thicker paint film thickness than sprayed on paint. If you cut off some of the paint around the circumference of the opening with a box cutter with a new blade you should be able to install the caps readily.
Old 09-03-2017, 11:41 AM   #3
Roadster5040
Thanks David that is what I was thinking was the problem. Have a good Labor Day!
