Old 04-22-2017, 02:52 PM   #1
Charlville
Charlville's Avatar
Default Ignition Wiring Problem Reverting to Points System
Hi Fellow Barners
I wonder if I can ask for an opinion on the issue with the ignition wiring on my 1929 Sport Coupe (12vol negative earth, with a Nu-Rex alternator)
I’m in the process of removing the Pertronix set up and replacing it with the Nu-Rex modern points setup.
I’ve taken the following steps:
Added a used base plate to which I’ve soldered the longer pigtail
Connected the pigtail to the points terminal without pinching as instructed
Additionally modified the dimple area where the pop out would normally contact and added a wire which I’ve carefully insulated and connected this to the live side of the coil along with the wire from the ignition switch to the positive side of the coil.
The negative side of the coil is connected to the driver side connection on the terminal box.
My problem is that every time I turn the ignition on I’m blowing the safety fuse.
So I have a short somewhere and I’m not the world’s best electrician therefore it’s probably self-inflicted
Any assistance or advice would be appreciated as I’m stuck in the garage with her at the moment
Regards
Kevin
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
