Old 01-01-2017, 04:02 PM   #1
29Phaeton
29Phaeton's Avatar
Default Broken manifold stud fix?
While trying to find an intake leak I decided to remove my manifolds. As I tried to loosen the second nut from the front it snapped. I can see it must have been bent from a previous install. I can tell two of the studs and brass nuts were newer with loctite.
Not the best way to start 2017! I'm not great with a torch so I'm thinking about drilling the center of the stud but don't want to hit to water jacket behind it. Any suggestions?
29Phaeton is offline   Reply With Quote
Old 01-01-2017, 04:29 PM   #2
Charlie Stephens
Default Re: Broken manifold stud fix?
I would try Jerry's Broken Drill and Tap Removal, (714) 836-6824.
Charlie Stephens
Old 01-01-2017, 04:59 PM   #3
H. L. Chauvin
Hi 29,
Any friendly Model A owners nearby?
Could be as fast as a tooth extraction with an experienced stud remover who could visit to "see" exactly what you have.
H. L. Chauvin is offline   Reply With Quote
Old 01-01-2017, 05:11 PM   #4
imacrazy
29Phaeton, I have removed a lot of studs on different manifolds IF you have any of the stud still sticking out so you can use a stud remover or vice gripes to get hold of it.
Use a torch and heat just the stud red hot, and then take a spray bottle and spray the stud with water, it will come right out.
imacrazy is offline   Reply With Quote
Old 01-01-2017, 05:17 PM   #5
DaWizard
Send a message via AIM to DaWizard
Is there any stud left? I have a stud puller but it needs about ¾" of stud to grab.
DaWizard is offline   Reply With Quote
Old 01-01-2017, 07:52 PM   #6
tbirdtbird
don't you just love previous owners and previous mechanics
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-01-2017, 08:08 PM   #7
Bigdave
Have an experienced welder tig weld an extension to the broken stud. Then treat with penetrant and try to loosen it.
Bigdave is offline   Reply With Quote
Old 01-01-2017, 08:38 PM   #8
29Phaeton
29Phaeton's Avatar
I got lucky, I was able to drill it and use an easy-out. Thanks to everyone who suggested their own technique. As a newbie it's great to have the community support when needed.
Old 01-01-2017, 10:29 PM   #9
tbirdtbird
good news!
you were exceedingly fortunate the easy-out did not break
'31 180A
Old 01-01-2017, 11:30 PM   #10
29Phaeton
29Phaeton's Avatar
I agree thanks! I heated up the stud with a torch as I tried to back it out and that worked.
Old 04-23-2018, 08:14 PM   #11
Mark A Johnson
What kind of drill bit did you use?
Mark A Johnson is offline   Reply With Quote
Old 04-23-2018, 08:56 PM   #12
Drive Shaft Dave
Using an Easy Out? I thought you would have better chance at winning the
lottery. Glad you got it out though.
Drive Shaft Dave is offline   Reply With Quote
