01-26-2016, 04:03 PM | #1 |
Pros & Cons of Insert Bearings
I had a "B" block rebuilt with inserts at Antique Engine Rebuilding in Skokie, IL.. It gets noisey when the engine has been running for awhile. I wonder if anyone else has had the same experience.
01-26-2016, 04:20 PM | #2 |
Re: Pros & Cons of Insert Bearings
what kind of noise , is it coming from the rods, mains, or valves, a little more info please
01-26-2016, 05:17 PM | #3 |
My "A" engine by Antique Engine runs noticeably quiet early and following a long ride. I use Mobil One 5W30 and change it every 500 miles or maybe three or four times a year. I do not burn any though I do sixty any time I am on a highway or open road. I have the Touring Package, HC head, touring cam, SS valves, etc.
01-26-2016, 05:26 PM | #4 |
My a engine used to get noisy when idled down when hot,turned out there was .009 clearance on the cam bearings.
Lawrie |
01-26-2016, 05:55 PM | #5 |
I had one of those engines in my coupe, and it was the best running engine I ever had, and the most powerful.
01-26-2016, 07:44 PM | #6 |
'31 180A |
01-26-2016, 09:24 PM | #7 | |
01-27-2016, 02:01 PM | #8 |
I can't think of a Con for insert bearings. Pro all the way.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-27-2016, 02:50 PM | #9 |
My inserts were done by Schwalms in PA, engine is so quiet you would think it was a Hybrid motor.
01-27-2016, 03:26 PM | #10 |
How many miles on it and what Pistons?
John - Kalamazoo, MI |
01-27-2016, 07:26 PM | #11 |
I'll try the engine oil suggestion
01-27-2016, 07:52 PM | #12 |
ya you wouldn't wanna give Rich a call
'31 180A |
01-27-2016, 09:12 PM | #13 |
01-27-2016, 09:27 PM | #14 |
01-27-2016, 09:27 PM | #15 |
what is the costs of inserts? if your engine makes noise try upping viscosity. or some lucas can quiet a noisy engine. i have run an old chev small block on 50 weight and it seems to love it 5 years on.
01-27-2016, 10:11 PM | #16 |
what i know for certain is that Rich stands behind his work
'31 180A |
01-28-2016, 12:26 AM | #17 |
5-20 oil is to thin for the engine, that thin of oil is used in modern engines to increase gas mileage use 20-50 in all of my older engines
01-29-2016, 12:56 AM | #18 |
The title is a bit misleading based on what you placed in the message.
01-29-2016, 03:41 PM | #19 |
X2, and what does that thin oil have to do with question For that matter (oil usage ) who recommends 5w20 for an antique engine use
01-29-2016, 05:07 PM | #20 |
