11-15-2020, 08:20 PM | #1 |
KR Wilson Combination Machine Raising Block
Anyone know what purpose this serves? Have been using a combo machine without one.Seems fine.
S |
11-15-2020, 09:07 PM | #2 |
Re: KR Wilson Combination Machine Raising Block
If it is what I think it is, would have been used when boring the cylinders, maybe not needed for doing the mains.
I know the voices aren't real but damn they have some good ideas! |
11-15-2020, 09:09 PM | #3 |
You use it when boring cylinders, it raises the block up slightly to make the boring bar and drive bar line up properly
11-15-2020, 10:46 PM | #4 |
Ah, I see
Has anyone used the Wilson machine to bore cylinders? I have not yet tried that feature. As I look at the Model A engine specs. it seems critical that everything is to specification and in the correct location. |
11-16-2020, 12:21 AM | #5 |
I have, it bores from the bottom up and leaves a very rough finish. You have to bore it out about .005 th undersize then smooth and bring out to final size with a precision cylinder hone I use a Sunnen hone. It is very slow, but if you have patience and the proper tools you can get very good results.
11-16-2020, 02:22 AM | #6 |
All turned out great with new pistons expanded to match each bore, for correct clearance. I did it for fun to see if it would work. I started with 220 grit stones. Next time I will start with 150 and plateau with 320, and it might go quicker with less shoulder damage (to me not the bores!) SAJ in NZ |
11-16-2020, 05:34 AM | #7 |
11-16-2020, 07:36 AM | #8 |
I have been using a Kwik Way bar but had often wondered about using the original KR setup.
11-16-2020, 08:50 AM | #9 |
The Model A engine bore is, if memory serves me right, 1/8" off center from what the Model T bore was. The plate is to raise the block to make up the difference when boring the cylinders.
11-16-2020, 05:12 PM | #10 |
Hello Bruce of MN,
I have a 1930's piston Koetheriser machine patented by Emil Koether. It squeezes the piston through the gudgeon bores into a more cammed shape, which is then set in by shot peening all around the gudgeon bossed inside the piston. There was a post showing one in a mobile truck by Old Car Mart on this forum a while ago. I expanded one piston 0.0095, another by 0.0055 and the other two by 0.004 inch. Engine now runs very quietly. Con rods were mismatched by 45 grams too. Evening-up both ends of all 4 rods by weight also made a big difference. Again not on a Model A, but a 2.5 litre English Riley. SAJ in NZ |
11-16-2020, 05:38 PM | #11 | |
Very interesting!
