Old 06-05-2021, 09:50 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Brake Drums
If you’ve ever cleaned up some 40 brake Drums you might have noticed a mark on them. This mark is there from the factory and is there to indicate the location of the wheel . The valve stem is supposed to be in close correlation to the mark for balance.
File Type: jpg 53AA7338-41F8-4BBD-9D4A-AF5AF1173E4B.jpg (67.9 KB, 457 views)
Ken/Alabama is offline   Reply With Quote
Old 06-05-2021, 10:44 PM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Brake Drums
Mark on Brake Drum on 1940 Fords to indicate where the position of the Valve needs to be for better wheel balance.
Very interesting.
Old 06-09-2021, 11:45 AM   #3
alchemy
alchemy's Avatar
So, is that the heavy spot or the light spot?
I always assumed the weight of the steel that was drilled out for the valve hole in the wheel was replaced by the weight of the rubber stem. But maybe the stem actually weighs more than the steel.
alchemy is offline   Reply With Quote
Old 06-09-2021, 01:33 PM   #4
19Fordy
19Fordy's Avatar
Ken, Are you sure about the reason for that mark? I can't imagine folks on the assembly line matching valve stem locations to brake drum marks. It would be tedious and hard to do, I think.
Perhaps that mark is was made in the manufacturing process of assembling the brake drum and inner hub.
Old 06-09-2021, 01:49 PM   #5
Ken/Alabama
I found this information in some Ford literature I have. I’ll look for it . Some drums have fins on them and have a notch on one of the fins.
Old 06-09-2021, 02:31 PM   #6
19Fordy
19Fordy's Avatar
Can't argue with the Ford literature. Still amazes me that an assembly line worker would be able to literally line up those marks. If so, I bet it was it was only done once - at assembly time.
Old 06-16-2021, 05:06 PM   #7
Ken/Alabama
Here’s the Ford service bulletin .
File Type: jpg C4EF9E44-AE8B-4CAC-BE06-BC9A08F12ADE.jpg (44.7 KB, 120 views)
Old 06-16-2021, 10:03 PM   #8
19Fordy
19Fordy's Avatar
Wow! That is very interesting. Thanks for posting that literature. I learned something new.
Wonder if the same "theory" is used when mounting today's tires?
Old 06-17-2021, 01:45 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
TODAY's "theory".......GIT 'ER DONE! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-17-2021, 10:35 AM   #10
3twinridges
3twinridges's Avatar
Nice info, I wonder if there were markings on 48-52 F1 drums? Amazing at the small details. I think there is a similar situation on 48-52 F1 fan hubs, one of the webs on the bearing is thicker to balance the fill hole and screw on the hub.
JB
3twinridges is offline   Reply With Quote
Old 06-17-2021, 10:56 AM   #11
rotorwrench
rotorwrench's Avatar
All bets are off if you have aftermarket drums.
