Old 04-22-2020, 04:23 PM   #1
Porfrm
Default 35 to 41 Flathead motor color
Have a 35 truck with a 41 Flathead. What was the original color of these year of flatheads? Can I get rattle can paint to use?
Porfrm is offline   Reply With Quote
Old 04-22-2020, 04:25 PM   #2
AlexLohmann1
AlexLohmann1's Avatar
Default Re: 35 to 41 Flathead motor color
35 is green. Bill Hirsch has the paint you need. Paint with a brush.
Sent from my SM-G975U using Tapatalk
AlexLohmann1 is offline   Reply With Quote
Old 04-22-2020, 04:27 PM   #3
AlexLohmann1
Here is the spray paint if you want to use that. You'll get better quality out of a hand painted surface though.
Old 04-22-2020, 04:39 PM   #4
Porfrm
Are you suggesting painting with a brush? Hand painting is fine with me. Thanks
Old 04-22-2020, 04:40 PM   #5
Porfrm
I see you did recommend a brush . Sorry
Old 04-22-2020, 04:56 PM   #6
philipswanson
Brush is best on cast iron. Nice thick coat. Get it super clean first with Prep-Sol or equivalent to remove oil film.
philipswanson is offline   Reply With Quote
Old 04-22-2020, 05:07 PM   #7
Porfrm
Thanks. Will a quart be enough for motor and transmission?
Old 04-22-2020, 05:22 PM   #8
JSeery
JSeery's Avatar
I've had good results with brushed on.
Old 04-22-2020, 05:57 PM   #9
Joe KCMO
Joe KCMO's Avatar
Quart is more than enough!
Joe KCMO is offline   Reply With Quote
