Old 04-03-2020, 03:40 PM   #1
Porfrm
Default 1935 Ford Model 51 truck driveshaft lubrication?
Hi! This is my virgin post on any forum. So bear with me please! I have a1935 Ford Model 51 Ford Truck. A 1 1/2 ton. 157 inch wheelbase. Enclosed driveshaft I believe it is called. Question, do you add oil to the first part of driveshaft? Pulled motor and transmission and shaft and U joint is oily. Thanks
Last edited by Porfrm; 04-03-2020 at 04:50 PM. Reason: Would like to include: Driveshaft question. In thread topic.
Porfrm is offline   Reply With Quote
Old 04-04-2020, 12:18 AM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 1935 Ford Model 51 truck driveshaft lubrication?
Yes, the universal joint must be lubricated. There is a zerk grease fitting on clamshell housing/covers to be used for this purpose. I use John Deere Corn Head Grease to lube the universal in my cars.
PS....welcome to Fordbarn!! You can get lots of good advice from most all members here. Don't hesitate to ask questions. Only dumb questions are those that are not asked
John
Old 04-04-2020, 05:58 AM   #3
Porfrm
Ok. It seems to me that there is quite a distance from zerk to universal joint in that clam shell. Is corn head grease lighter than a regular grease? Or do you have to pump in a lot? Thank you for your response and time.
Old 04-04-2020, 08:51 AM   #4
JM 35 Sedan
If, or when I'm assembling my cars, (engine, trans, or rear) I apply the Corn Head Grease all over and around the universal joint by whatever means available at that time (I call this buttering), then after everything is back together, I add more (a little more) JDCHG in through the zerk fitting using a grease gun, ....but not so much that it's forced into transmission, out through clam shell gaskets, or back past lip seal in torque tube.
John
Old 04-04-2020, 09:40 AM   #5
1931 flamingo
1931 flamingo's Avatar
On a wheelbase that long there must be a center bearing with a zerk also??
Paul in CT
Old 04-04-2020, 10:45 AM   #6
Bob C
Here is a lube chart for the truck chassis. I would use corn head grease for the u-joints.
Bob
Bob C is online now   Reply With Quote
Old 04-04-2020, 08:48 PM   #7
Porfrm
Howdy. Yes there is a center bearing also with a zerk. That pretty well answers my question. I am a farmer and I inherited this truck from my father. It was not started for 35 years I got it running last spring and was just gonna clean it up. I am now done to bare frame! Just couldn’t stop! My first restore . Thanks for help. I will have more questions I am sure.
Old 04-04-2020, 09:28 PM   #8
tubman
tubman's Avatar
Sounds like you caught the "as long as I'm this far, I might as well...." disease.
It is endemic with most of us.
Old 04-05-2020, 02:06 PM   #9
nelsb01
nelsb01's Avatar
This is what the u-joint housing looks like without any grease in it
nelsb01 is offline   Reply With Quote
Old 04-05-2020, 05:40 PM   #10
Porfrm
so Both of the housings should be full of grease? The one right behind the transmission was just real oily. I wondered if it didn’t oil through the ball bearing in the rear of transmission. There is a zerk on both.
Old 06-07-2020, 06:36 PM   #11
Model51
Model51's Avatar
I also have a '35 Model 51 157" truck and am doing a complete restoration. I had to remove old grease from both universal joints and the clamshells. All of the external parts were sandblasted and painted. I too used John Deere Corn Head grease which comes in tubes. Lathered it all over the universals. This grease has the property of mostly staying in place but slightly melting where parts slide against each other.
I have most all of the Ford literature and printed materials related to Model 51 Fords. I'm happy to do my best to answer any questions you have.
Model51 is offline   Reply With Quote
Old 06-07-2020, 08:04 PM   #12
KDL
KDL's Avatar
Guess I should get myself some corn head grease.
KDL is offline   Reply With Quote
Old 06-08-2020, 12:03 PM   #13
Model51
Model51's Avatar
Hopefully I've attached an image of a tube of John Deere Corn Head grease. A few years ago the only way to get it was to purchase a case of 12 from the local John Deere dealer by special order. I split case of 12 tubes and cost with others in my local car club.
I was told that this grease was developed for use on the corn combines for lubricating the cutter heads which see long,dry and dusty conditions on the hot farm fields cutting corn stocks near the ground were standard grease would just not hold up. Not sure if this is truth or fiction, you can decide, but no matter as it's the lubricant I'm going to use for the universal joints.
