03-07-2024, 05:33 AM | #1 |
33 Tudor turn signals
I plan on installing turn signals on my 33 ahead of this years driving season using LEDs. I already have the taillight LEDs. I want to use the cowl lamps as the front turn signals, they don’t necessarily have to be a dual function as a cowl lamp. Turn signals are my main concern. Is the 3” cowl lamp one big lamp or is there a small replaceable bulb inside? If not, are LED cowl lamps available? I understand I’ll need a special flasher to handle the LEDs. Any and all help appreciated.
For you judging naysayers I’m looking at functionality, not points on the concourse.
Tim Carlig Last edited by dean333; 03-07-2024 at 05:44 AM. |
03-07-2024, 05:48 AM | #2 |
Re: 33 Tudor turn signals
There is a standard single filament bulb and socket in the cowl lamp.
03-07-2024, 08:11 AM | #3 |
Tim
Should be a pretty easy installation all in all for you. We did the same thing on our 32 with a little clever thought it can be a pretty hard to notice conversion sans the turn signal indicator housing and arm. |
03-07-2024, 11:32 AM | #4 |
For a turn switch look at the early VW turn switch. They clamp right on the column and look like they might have come from the Ford factory.
03-07-2024, 12:27 PM | #5 |
03-07-2024, 12:28 PM | #6 |
Tim Carlig Last edited by dean333; 03-07-2024 at 12:35 PM. |
03-07-2024, 02:47 PM | #7 |
Just for the judging folks; '33 cowl lamps are a bit longer than the '34s. I checked my Vintiques and they are '33s !!! Newc
03-07-2024, 04:53 PM | #8 |
03-07-2024, 06:06 PM | #9 |
This definitely will not just clamp on to the column.
Tim Carlig |
03-07-2024, 06:43 PM | #10 |
03-07-2024, 06:57 PM | #11 |
This is a 1953-59.
03-07-2024, 08:56 PM | #12 |
03-08-2024, 01:23 PM | #13 |
The 53-59 ones work and so do some of the VW bus units into the early 60s.
03-08-2024, 04:02 PM | #14 |
I once used a 49 Ford switch on a 48 Ford. It had a cancellation lever screwed to the back side of the steering wheel. It transferred over to the 48 no problem. It was heavy chrome and a Ford oval on the frontside.
