Old 11-27-2021, 01:54 AM   #1
Shampipple
Shampipple's Avatar
Default 39 Frame- Worn wishbone socket
The front wishbone ball socket on my 39 frame is toast. I was considering using pieces of a Model A two piece socket as a repair. Does anyone sell a patch kit, or is this the suggested fix? Otherwise I'd have to fabricate one and weld it in.
Thanks in advance, this is the BEST place for advice on this old iron!
29 Model A Roadster, 39 Pickup, 50 Custom Tudor, 66 Mustang Fastback, 79 F350, 02 Thunderbird
Shampipple is offline   Reply With Quote
Old 11-27-2021, 07:07 AM   #2
Mart
Mart's Avatar
Default Re: 39 Frame- Worn wishbone socket
Could you not just use a second lower part as a new upper seat? Bolts in and a couple of decent weld beads would make sure it doesn't move. Slightly longer bolts might be needed.
Can I just check.. You do realise there is a rubber ball used in that location?
Mart.
Old 11-27-2021, 11:18 AM   #3
Shampipple
Shampipple's Avatar
Yes, I have purchased another cover and a rubber cover. I was just curious what others say.
Old 11-27-2021, 11:25 AM   #4
RalphM
RalphM's Avatar
Can you find one off a junk frame and just replace it? Wouldn’t 35-40 ball socket all be the same?
RalphM is offline   Reply With Quote
Old 11-27-2021, 12:02 PM   #5
Shampipple
Shampipple's Avatar
I guess thatís what Iím trying to do. Not many left in the rust belt.
Old 11-27-2021, 12:45 PM   #6
Karl Wolf
Karl Wolf's Avatar
VIN Numbers are stamped on the left frame rail...
I like the two caps idea. Or the model a parts.
Karl
Karl Wolf is offline   Reply With Quote
Old 11-27-2021, 12:54 PM   #7
Bob C
Don't think the Model A parts will work as they didn't use the rubber ball
like the later Ford's. The aftermarket rubber ball for the Model A's used cast
upper and lower metal parts.
Old 11-27-2021, 01:28 PM   #8
Shampipple
Shampipple's Avatar
I ordered a handful of pieces. Iíll post a photo before and after when itís fixed.
Old 11-28-2021, 06:07 PM   #9
Shampipple
Shampipple's Avatar
Before
Old 11-28-2021, 06:08 PM   #10
Shampipple
Shampipple's Avatar
During
Old 11-28-2021, 06:08 PM   #11
Shampipple
Shampipple's Avatar
Grinding
Old 11-28-2021, 06:09 PM   #12
Shampipple
Shampipple's Avatar
Done.
Old 11-28-2021, 06:19 PM   #13
Lawson Cox
Lawson Cox's Avatar
Wow. To call that Toast, insults toast. Waiting on some "after" photos.
Old 11-28-2021, 06:36 PM   #14
Shampipple
Shampipple's Avatar
They are uploaded.
Old 11-28-2021, 07:50 PM   #15
Lawson Cox
Lawson Cox's Avatar
They are not showing up here.
Old 11-28-2021, 07:54 PM   #16
Bob C
I can see them.
Old 11-29-2021, 02:33 AM   #17
deuce lover
deuce lover's Avatar
Pics in post #11 & #12 are the repairs?
Old 11-29-2021, 03:27 AM   #18
V8COOPMAN
V8COOPMAN's Avatar
Something we made-up from some saved scraps & a machined receiver chunk of steel. DD
Click Links Below
T5 W/TORQUE TUBE
Old 11-29-2021, 11:50 AM   #19
Shampipple
Shampipple's Avatar
V8COOPMAN you are an artist!
Old 11-29-2021, 12:04 PM   #20
19Fordy
19Fordy's Avatar
V8: Your engineering is super nice. Does your repair change the castor angle?
