Old 05-11-2021, 11:24 AM   #1
Wayne Schuenke
Default need a little help
Need a little help when checking the OD solenoid I ground the case to the frame works of the car the do I put the neg. or the pos. wire to post a on the solenoid ?
Wayne Schuenke is offline   Reply With Quote
Old 05-11-2021, 12:43 PM   #2
joe 1950
joe 1950's Avatar
Default Re: need a little help
is it 6 volt or 12 volt are you using a car battery?
joe 1950 is offline   Reply With Quote
Old 05-11-2021, 12:54 PM   #3
Wayne Schuenke
6 volt pos ground
Old 05-11-2021, 01:02 PM   #4
joe 1950
joe 1950's Avatar
put the neg wire on the post remember a battery charger doesn’t have enough amps to engage it l always use the battery and like you said ground the case
