Old 05-10-2021, 03:18 PM   #1
rottenron36
rottenron36's Avatar
Default 59ab oil pressure sending unit
I believe my oil pressure sending unit is shot. Is there a way to test one. If it is not good, There are 50 and 80 units. Which is correct for a 59ab. Thanks Ron
rottenron36 is offline   Reply With Quote
Old 05-10-2021, 03:30 PM   #2
flathead48
Default Re: 59ab oil pressure sending unit
80 lb, test it by using a mechanical gauge.
flathead48 is offline   Reply With Quote
Old 05-10-2021, 08:36 PM   #3
HD Rider
If your gauge reads to 80psi, use the 80psi sender.
If it only reads to 50psi, use the 50psi sender.
HD Rider is offline   Reply With Quote
Old 05-11-2021, 07:17 PM   #4
36coupe
36coupe's Avatar
Are they marked in any way to identify?
36coupe is offline   Reply With Quote
Old 05-11-2021, 07:35 PM   #5
ford38v8
ford38v8's Avatar
All 80 lb senders are marked 80 on the bottom. 50 lb senders may be marked 50, or not marked at all.
Alan
