Old 10-11-2015, 11:33 PM   #1
dixiedelux
dixiedelux's Avatar
Default Distributor Interchangeablility
Hello Barners! Is a 46-8 distributor interchangeable to a 24 stud 1940 block?
dixiedelux is offline   Reply With Quote
Old 10-11-2015, 11:52 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Distributor Interchangeablility
Yes, but you may need a "button" spacer due to the difference in how much of the distributor sticks out the back. All the major suppliers sell this. You do know that the 46-8 distributor is a 2 bolt and you will need to change timing gear covers as the 40 is a 3 bolt one. There are also adapters instead of changing the timing gear cover but I would choose changing the cover.
Old 10-12-2015, 12:11 AM   #3
dixiedelux
dixiedelux's Avatar
Thank you very much for the info! I am trying to help a friend out who thinks the 40 engine in his 36 coupe has an earlier distributor. He thinks my 46 type distributor is called for on his 40 engine. I will go tomorrow and see what he has.
Old 10-12-2015, 07:25 AM   #4
zzlegend
zzlegend's Avatar
As deuce roadster stated.
http://www.speedwaymotors.com/Flathe...olt,25076.html
http://www.speedwaymotors.com/Flathe...pter,6003.html
zzlegend is offline   Reply With Quote
Old 10-12-2015, 07:33 AM   #5
dixiedelux
dixiedelux's Avatar
Thanks for the links, ZZ!
Old 10-12-2015, 07:37 AM   #6
zzlegend
zzlegend's Avatar
Your welcome
