10-29-2020, 12:07 AM | #1 |
How much spindle wear is acceptable?
Just 2,000 miles since the front axle was rebuilt, and I just found some play in the right spindle. It looks like its all in the top bushing. It moves enough to give a click-click, 10-20 thousands or so. So I either over reamed it, or it's not getting enough grease.
Do I wait until it wears more or vibrates? I know in an ideal world it would get replaced now, but the to-do list is already long. |
10-29-2020, 03:37 AM | #2 |
Re: How much spindle wear is acceptable?
Are you sure it isn't play in a worn axle eye? Or even a loose cotter pin king pin retainer (cannot think of the correct USA term for it but I don't mean what we limeys call a split pin and you call a cotter pin). My axle eye has an 8 thou split shim to take up slack. Cut to fit around said retainer cotter. It has all stayed tight for 20000 miles so far, despite some criticism from other experts who say I should shrink the axle eye or bore and solid bush it.
SAJ in NZ |
10-29-2020, 11:26 AM | #3 |
All I know is that the king pin bushings (which sounds what you are describing) there should be no noticeable play. If there is then they need to be replaced. The king pin should be good just the bushing may be bad. I am assuming there are no other issues here as well.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-29-2020, 12:54 PM | #4 |
I get about 1 inch of movement at the wheel. It's one of the things on my list, I used a reamer/driver tool sold in the 70s, it chattered, they were very tight at first, then got loose quickly, but the car has no bad habits because of it at this moment, got the parts, and sunnen hone, and other higher priority problems, after 50 years since I restored it it is due again for more than just kingpins
10-29-2020, 01:59 PM | #5 |
10-30-2020, 11:34 AM | #6 |
10-30-2020, 11:48 AM | #7 |
Yes 1 inch at tire, drives , brakes normal, stable at 60, normal tire wear, but on rough roads I can tell it is too loose and trying to think about death wobble
10-30-2020, 01:18 PM | #8 |
What is death wobble? Some kind of resonance?
10-30-2020, 03:32 PM | #9 |
10-30-2020, 06:28 PM | #10 |
Between king pin and bushing you should have about .001 clearance.
One inch at the tire tread is way loose and could be from the inner and outter wheel bearings or the tapered pin has not been driven in tight to hold the king pin tight in the axle or loose lug nuts. Al |
11-01-2020, 01:13 PM | #11 |
Lots of wear can be got by with if the toe in is correct . Toe in keeps the wheels going in a straight line . Toe out will set up a shimmy at certain speeds and conditions that is often referred to as death wobble . Once the shimmy begins , any looseness in the front end will contribute to death wobble . Correct toe in should be one sixteenth . A weak front spring will cause shimmy , so can under inflated rear tires .
11-01-2020, 07:35 PM | #12 |
Seems like the question might be what type of reamer did you use? Is it a 2 stage reamer specifically made for King Pins? If not, chances are the two bushings in the spindle were not reamed in the same plane or along the same center axis. This would cause the likely scenario of wear occurring over a short period of usage.
Focus on the logical issues involved in work you just performed before worrying about other front end issues. Your issue is a prematurely worn upper bushing on one spindle. I agree with others that you might be noticing movement of the king pin in the axle but, if you rule that out, why is this bushing showing wear so soon after servicing? Bob Bader |
11-01-2020, 08:22 PM | #13 |
MisterMoose _ I am in the process of getting my spindles reworked (bushings) only to find that the axle is egg shaped, but before taking it apart I was convinced it was the spindle bushings! As to you comment of the top bushing not getting enough grease, I too was thinking the same thing. I actually have been thinking of drilling the upper spindle/bushing and installing a grease zerk fitting
11-02-2020, 02:50 PM | #14 |
Mr. Moose are referring to the steering wheel ?
11-02-2020, 03:03 PM | #15 |
No, not the steering wheel.
It's too long ago to be sure, but I would guess I used a relatively inexpensive reamer, or no reamer at all. They were not done by a shop or honed. I did the front axle in 1980, then got involved in work, got the car restored and on the road in 98-99, and have put 1,700 miles on it. I'm sure I made an amateur mistake of some kind. I'll try to get a short video of the visible play up in the next week, maybe that will help. |
Thread Tools | |
Display Modes | |
