Old 10-24-2020, 02:28 PM   #21
40cpe
40cpe's Avatar
Default Re: Overdrive transmissions
the lighting in the first picture of post # 1 is not good, but when I blow up the picture I think I see the clutch boss on the side cover. Have you looked for the boss on the transmission in post #1?
40cpe is offline   Reply With Quote
Old 10-24-2020, 02:31 PM   #22
Alberta50fordor
Alberta50fordor's Avatar
I haven’t had a chance to look at it in person but now that you mention it does look like it has the boss for the clutch linkage.... did they use the same side cover on newer transmissions?
Alberta50fordor is offline   Reply With Quote
Old 10-24-2020, 03:12 PM   #23
40cpe
40cpe's Avatar
'49 to '51. Ford went to swinging pedals in '52.
Old 10-24-2020, 03:18 PM   #24
Alberta50fordor
And they didn’t keep using the old side covers?
Old 10-25-2020, 10:37 AM   #25
rotorwrench
rotorwrench's Avatar
They didn't need them with the swing pedals starting in 1952 so the side cover has no extra mounting provisions. The one in your car also has the boss on the right side for right hand drive set ups for export to Australia and New Zealand. That's a Canadian Ford thing since they supplied a lot of stuff to the commonwealth countries.
If the tail shaft is different on the later transmission then it would take more work to use the later one. If it is the same, then it may be adaptable using the side cover from the one in the car. There may be a difference in gears but gears can sometimes be swapped as long as the whole set is used from the donor. If the later transmission can be identified then a person can find out for sure. Mac VanPelt of VanPelt Sales is the best guy to call on the Ford units. He also has a good book for the early Ford transmissions. A lot of the info crosses over. I use my 1949 thru 51 Lincoln Mercury overhaul manual to do my overdrive units.
Old 10-25-2020, 10:56 AM   #26
Alberta50fordor
You mean the first and second gear ratios are different or the construction? I’m going to try and pull my trans and compare it to this other one(either way mine has to come out)
Old 11-01-2020, 07:12 PM   #27
Alberta50fordor
Well it turns out that that transmission is a 49-50 car transmission, it’s exactly the same as mine and the numbers are the same, my transmission also has the c8 number on it, got it in yesterday and works good
