Old 10-12-2020, 06:54 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default 1932 Ford 4 cylinder engine tins question
Looking to learn some more about the Deuce.
What's the correct name for the metal covers located along side of the four cylinder engine in the 1932 Ford chassis? Our Deuce sedan has one on the right side but the one on the driver side is missing should there be one on this side also?
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 10-12-2020, 07:12 PM   #2
Aarongriffey
Default Re: 1932 Ford 4 cylinder engine tins question
Should be on both sides.
We always called ‘em engine pans.
They are usually both missing.
The last model A I worked on, a ‘30 roadster with a Russian B engine, has both pans.
Aarongriffey is offline   Reply With Quote
Old 10-12-2020, 07:56 PM   #3
Charlie Stephens
Ronnieroadster
I always called them engine splash pans. Do your homework before you go shopping. I assume you have a copy of "The 1932 Ford Book" from the Early Ford V8 Club. There is an early drivers side pan without the cut out for the brake rod. There is also a different drivers side pan for the BB trucks with a larger depression to clear the larger truck steering. There are also different pans for the right hand drive cars.
Charlie Stephens
Old 10-12-2020, 09:47 PM   #4
DavidG
DavidG's Avatar
Here's a photo of the most common variety from the V8 Club book that Charlie cites. Note the slot to clear the brake rod in a serious front spring jounce. Model B engine splash pans seem to have survived better than the V8 versions, likely because they don't interfere with normal engine compartment service routines as do the V8 versions when it comes to replacing the exhaust system forward of the muffler.
Old 10-13-2020, 01:08 PM   #5
Ronnieroadster
Thanks Guys we now know what to look for when hunting for the missing engine splash pans.
Old 10-13-2020, 05:36 PM   #6
35fordtn
35fordtn's Avatar
Ronnie,
If you need a driver's side I've got a few floating around.
35fordtn is offline   Reply With Quote
Old 10-20-2020, 05:04 PM   #7
d.conrad
d.conrad's Avatar
Are 4 cylinder pans the same as V8
d.conrad is offline   Reply With Quote
Old 10-20-2020, 06:03 PM   #8
Charlie Stephens
They are totally different.
Charlie Stephens
Old 10-20-2020, 06:19 PM   #9
DavidG
DavidG's Avatar
Night and day difference (compare the photos in the two threads running side by side at present herein, both of which you have participated in).
Old 10-20-2020, 11:00 PM   #10
earlyride
earlyride's Avatar
In all the original 32's I've seen I can't remember seeing those on any cars, so they must be pretty rare. What were they designed to do and did they work as designed?
earlyride is offline   Reply With Quote
Old 10-21-2020, 06:29 AM   #11
DavidG
DavidG's Avatar
Fairly rare, but not unheard of; for example six of seven of the more or less original '32s in the Regehr auction in Kansas later this week still have their engine splash pans intact, both fours and V8s.
The purpose was to keep the ignition system dry by preventing rain water from being splashed up into the engine compartment by the front wheels, hence "splash pans".
Old 10-21-2020, 07:41 AM   #12
rockfla
rockfla's Avatar
AND you can say that for just about all the years hence forward, 33.34.35 etc etc.....Unless the owner is more "concours" minded MOST years you will find them "missing". It's my first "go to" item when looking at cars engine bay, "usually" IF the car has its "engine tins" take notes from there on because the owner "generally" has paid attention to the "Details". JMO
rockfla is online now   Reply With Quote
Old 10-21-2020, 01:21 PM   #13
earlyride
earlyride's Avatar
Thanks David and Rockfla for clearing that up for me, when I bought my 32 it did not have those
Old 10-21-2020, 01:57 PM   #14
rockfla
rockfla's Avatar
Earlyride
When most people acquire their car they weren't there to start so IF you are not "versed" on the year THEN most don't even know they had them!!! As DavidG said, they were "generally" tossed aside long ago as they were seen as a PITA (Just in the way) and I'm sure most thought "unnecessary"!!! That is why, NOW they are thin on the ground as they were gone long ago and not removed by the car owner and saved in the rafters of the garage AGAIN as DavidG said "TOSSED"!!!!
Old 10-21-2020, 03:46 PM   #15
Ronnieroadster
Originally Posted by 35fordtn View Post
Ronnie,
I'm interested tried sending you a PM but your mail box is full. Please send me a PM with contact info.
Thanks Ron
Old 10-21-2020, 03:54 PM   #16
rockfla
rockfla's Avatar
Mike at Third Gen Auto OR (35FordTN) 844-327-5988
Old 10-22-2020, 09:07 AM   #17
1931 flamingo
1931 flamingo's Avatar
Best to call him.....................
Paul
Old 11-06-2020, 05:52 AM   #18
deuce lover
deuce lover's Avatar
A set of V8 ones on EBAY now.$980.
deuce lover is offline   Reply With Quote
Old 11-06-2020, 06:50 AM   #19
DavidG
DavidG's Avatar
Despite the seller's claim, only the right side pan of the pair is for a '32 V8. The left side pan is for a four (note the absence of an opening for a crossover pipe).
Old 11-06-2020, 07:44 AM   #20
deuce lover
David,I hope you mentioned it to the seller.
