Old 09-29-2020, 10:38 AM   #21
ford38v8
ford38v8's Avatar
Default Re: hunting a ghost problem in my '47
Originally Posted by RKS.PA View Post
ford38v8, my '47 is pretty original...at least I think it is....and I have a resister under the dash...not down by my Skip's rebuilt coil. Doesn't look like an "after market" modification.
That's my bad. The resistor did remain under the dash through early '47, when it was relocated to the coil mount at the front left side of the engine. I don't have the change date. This applied only to the V8's, as the 6 cylinder coil had an internal resistor. I apologize for the confusion.
Alan
Old 09-29-2020, 12:43 PM   #22
RKS.PA
RKS.PA's Avatar
Originally Posted by cabrioletgalaxie View Post
RKS, can you text me a photo? That would be helpful.
Thanks. D
207-590-0180
Sent. Hope this helps.
RKS.PA is offline   Reply With Quote
Old 09-29-2020, 12:45 PM   #23
RKS.PA
RKS.PA's Avatar
No worries....think my car was a mid-47. Does have the "face lift" etc. but not sure of manufacture date.
Old 09-29-2020, 12:54 PM   #24
RKS.PA
RKS.PA's Avatar
Thanks. D
207-590-0180
D. just in case my test didn't come through.
Old 09-29-2020, 04:51 PM   #25
Aarongriffey
All ‘32 through ‘48 cars and trucks used the ‘32 V8 resister mounted on the inside of the firewall except ‘48 and later trucks which were 8ba powered.
It was the same part number ‘32 through ‘48, V8 and 6 cylinder.
The four cylinder cars ‘32-‘34 (with B engine) did not use it. They used their own 4 cylinder coil.
‘48 and later trucks and ‘49 use the model B 4 cylinder coil.
Aarongriffey is offline   Reply With Quote
