Old 06-16-2020, 07:34 PM   #1
shew01
shew01's Avatar
Default Emergency Brake Boot
When I removed the carpet so that I could remove the floorboard, I had to arm wrestle with the emergency brake boot to free it from the carpet. I’m getting ready to but the carpet back down.
What is the best way to get the boot back where it needs to be in the carpet? There has to be a better way... Should I remove the emergency brake handle and slide the boot off? Maybe I’m missing something.
shew01 is offline   Reply With Quote
Old 06-16-2020, 07:50 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Emergency Brake Boot
I believe the carpet is supposed to be on top of the boot if that makes sense, so you can just slide the carpet on top of it. Unless I am misunderstanding the question?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-16-2020, 08:27 PM   #3
shew01
shew01's Avatar
This one is a really tight fit. The previous owner had the carpet just above the final rectangular flat part of the boot. I hesitate to make the carpet hole bigger—I don’t want the carpet to fray.
Old 06-16-2020, 09:01 PM   #4
J Franklin
J Franklin's Avatar
It's rubber, be the boss! You can't hurt it.
Old 06-16-2020, 09:11 PM   #5
shew01
shew01's Avatar
Well... that was way I got off in the first place. I was just home there was a more “graceful” way to do it. ;-)
I did buy a spare boot. I just don’t want to tear up the carpet. I thought there might be a technique that I was missing.
Old 06-16-2020, 09:14 PM   #6
Brian SATX
Brian SATX's Avatar
Try putting some Dawn/water on the boot to make the carpet slide down easier.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 06-16-2020, 10:48 PM   #7
bavArian
bavArian's Avatar
Vaseline is an option, just don't let anyone see you lubing up that rubber.
bavArian is offline   Reply With Quote
Old 06-17-2020, 08:17 AM   #8
Will N
Will N's Avatar
FYI, although you probably know this, the Model A originally came with no boot on either the parking brake or the gearshift lever.
Will N is offline   Reply With Quote
Old 06-17-2020, 11:13 AM   #9
DBrer
I just installed my floor boards and used spray silicone on the boots, it worked great they slid right on no problem.
DBrer is offline   Reply With Quote
Old 06-17-2020, 04:15 PM   #10
shew01
shew01's Avatar
No, I didn’t know that. Thanks for sharing.
