04-01-2020, 04:25 PM | #1 |
What lube for '39 vacuum wiper motor?
I need to lubricate a wiper motor. It starts to make squeaky noises after operating for a few minutes. What should I use?
04-01-2020, 04:39 PM | #2 |
Re: What lube for '39 vacuum wiper motor?
In my '53, I removed the rubber vacuum hose from the base of the carb and shot some GIBBS Oil into it. The wiper motor freed up instantly and operated like new....It's best to use the long plastic applicator tube supplied with the GIBBS Oil when doing this.
04-02-2020, 10:05 AM | #3 |
I have read others saying just use any light weight oil. My ‘40 came to me with wipers frozen and I had same success as mentioned above. I pulled the motor(not difficult on a ‘40), a few drops of 3-in-1 light oil into the vacuum port, freed up instantly, now works like new.
04-02-2020, 10:16 AM | #4 |
Thanks for answers! Gibbs oil is not available in Russia. Is WD40 a substitute?
04-02-2020, 10:21 AM | #5 | |
Ken |
04-02-2020, 10:26 AM | #6 |
Enjoy yer day. Tom Hate can't fix what it started. |
04-02-2020, 10:48 AM | #7 | |
I wondered about just pulling the hose as you did but didn’t think it would work since it drawing air away from the motor,i.e. vacuum line. In my 40 pulling the motor would not be easy. |
04-02-2020, 10:53 AM | #8 |
Under what might be available to moonraker: I was thinking ATF, since it is a lite oil?
04-02-2020, 11:11 AM | #9 |
Sewing machine oil...must be available worldwide...thin and designed to lube..usually high quality and in a small container...
04-02-2020, 11:12 AM | #10 |
I can find sewing machine oil
04-02-2020, 11:26 AM | #11 |
With the hose disconnected, operate the wiper blade manually. Moving it in one direction (I forget which) creates a vacuum on the inlet.
04-02-2020, 03:44 PM | #12 |
Thanks Tubman that makes good sense.
Glenn |
04-02-2020, 08:11 PM | #13 |
Don't use WD-40 as it can cause pot metal to swell and ruin the wiper motor. light oil or open it up and use light grease.
04-03-2020, 07:20 AM | #14 |
I just found this great article on "Lubricating the Vacuum Wiper Motor". My motor is very stiff so I'll be just oiling using Marvel Mystery Oil, MMO, I know it is good for the leather in my Columbia vacuum canister so a good choice here.
I know that brake fluid and ATF will swell rubber and give a better seal. I'm not sure how it acts on leather which is used on the wiper motor internal paddle. https://www.mafca.com/downloads/Tech...um%20Wiper.pdf Glenn |
04-03-2020, 07:47 AM | #15 |
... and a couple of patent office documents:
04-03-2020, 10:53 AM | #16 |
Here's how to lubricate the motor, which should be done three or four times a year: 1. Remove the vacuum hose at the wiper motor. Lightly hold your finger over the hose nipple on the motor and cycle the wiper blade back and forth.. Note that in one direction the motor sucks in air, and in the opposite direction, the motor expels air through the nipple. Place the wiper blade in the position such that the motor will begin to suck air at the nipple. 2. Attach a six‐inch long piece of hose to the motor nipple and hold the open end up. Using a squeeze bottle, force one teaspoonful of lubricant into the hose. Place a rag on the cowl below the wiper motor. Hold another rag over the open end of the hose. 3. Cycle the wiper blade back and forth several times. Repeat the process again, adding a second teaspoonful of lubricant. 4. Start the engine and run the wiper motor. It should run well. If it does not, the wiper motor should be disassembled, cleaned, inspected and a rebuilding kit installed. It is normal for the wiper to slow down when the car is accelerated, but it should not stop altogether. [Editor Note: Using brake fluid as a lubricant is not recommended by Chuck Christensen, 2012 MAFCA Technical Director, as spilled brake fluid can damage the car's paint, either during the lubrication or afterward during wiper use. Instead, use a light machine oil.]
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 04-03-2020 at 11:06 AM. |
04-03-2020, 10:55 AM | #17 |
The instructions I have see say to use brake fluid.
04-03-2020, 10:57 AM | #18 |
Can you post the instructions you have please?
04-03-2020, 11:07 AM | #19 |
04-03-2020, 11:23 AM | #20 |
I used brake fluid in the wiper motor of my '51 and it helped a lot. Using a bit of care can prevent paint damage from the brake fluid.
