Old 03-28-2020, 06:54 PM   #1
doug.nichols
doug.nichols's Avatar
Question Stuck GAV
I just re-installed my zenith carburetor (new from Snyder last year) after replacing the exhaust and intake manifolds. The GAV/choke adjustment rod will now not turn. It appears to be suck at the carburetor. What have I done?
doug.nichols is offline   Reply With Quote
Old 03-28-2020, 08:30 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Stuck GAV
Give it some light lube. Some are quite tight.
Old 03-28-2020, 08:36 PM   #3
doug.nichols
That seems to have worked.....
Old 03-28-2020, 09:18 PM   #4
Joe K
Joe K's Avatar
The "fingers" can be adjusted. I used an ice pick pushed down into where the GAV needle fits to bend slightly the fingers and the "c-clip."
Alternatively you can remove the c-clip and try that. Or replace the c-clip with a small o-ring.
Careful with expanding the fingers - it's possible to "break" one of the fingers off - although in my case it didn't affect the function, and actually served to make the GAV needle turn easier. (I haven't repaired/replaced it yet as there is no need.)
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-29-2020, 04:02 AM   #5
johnbuckley
johnbuckley's Avatar
sorted. but for future ref add... rare but the thermal contraction sometimes trap the needle if already screwed in tight to port. And I have had report of a nick on threads making it v stiff to turn
johnbuckley is offline   Reply With Quote
