Old 01-20-2020, 12:44 PM   #1
David R.
Default Sealing wax on condenser?
On page 214 of service bulletins it says to remove the sealing wax from condenser screw to remove. What was the reasoning behind the wax? To prevent the screw from loosening; or seal the distributor? Any ideas? I have sealing wax.
David R. is offline   Reply With Quote
Old 01-20-2020, 01:19 PM   #2
Brian T
Brian T's Avatar
Default Re: Sealing wax on condenser?
The plug was for keeping out moisture, the vendors have them.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 01-20-2020, 02:17 PM   #3
Ray in La Mesa
The plugs are a great idea. I have closed another hole that allows moisture into the distributer, the slot for the top plate arm the spark advance rod goes to, it's huge and allows moisture directly in to corrode the points. I cut a piece of inner tube large enough to cover the hole and cut a slot in it for the arm & it's movement. I then unhooked the rod and slid it over the arm and contact cemented it to the outside of the distributer upper body. If your A lives outside like our "yard art" on the front lawn does, this will keep it starting regularly.
Ray in La Mesa is offline   Reply With Quote
Old 01-25-2020, 04:43 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Sealing wax melts at much too low a temperature to be used on the distributor.
I melted some of it years ago, and took the temp when it melted.
Old 01-25-2020, 06:46 PM   #5
Flathead
Flathead's Avatar
A+L sells a nice plug for that purpose.
Flathead is offline   Reply With Quote
Old 01-25-2020, 06:57 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Or, you could just move to a drier, less humid climate.
Old 02-03-2020, 07:33 AM   #7
H.Colledge
Hi - does anyone know the model of the condenser used when fitting modern points and condenser on a Model A? I think it may be an FD-95 as fitted to a 1970s Ford but am not sure. I'm looking to get hold of a new old stock / good quality part rather than a repro one if possible as I think the quality may be better. Any help much appreciated. Thanks
H.Colledge is offline   Reply With Quote
Old 02-03-2020, 11:22 AM   #8
katy
katy's Avatar
https://www.fordbarn.com/forum/showt...tributor+plate
Read post #4
