Old 01-18-2017, 08:23 PM   #1
chapsetc
Default Engine rattles
I have new re-built model A engine
And when I start it up, there is a rattling and squeaking sound coming from the block and the rattling sounds gets louder the faster the engine runs
And it has a ruff idea
Dose any one have a I idea what it could be
chapsetc is offline   Reply With Quote
Old 01-18-2017, 09:26 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Engine rattles
When people don't put a good coat of grease on the cam plunger, it will squeak for quite a while. I started an engine that someone else rebuilt, and I did several short runs to warm it up and let it cool down. After about a couple hours run time the squeak finally quit. I like to put a coat of Mystik JT-6 High Temp grease all over the timing gears, plunger, and cam lobes.
Who rebuilt the engine, and can you pinpoint the rattle to some part of the engine by using a stethoscope? Loose rods and loose pistons can rattle. I'd assume a rebuilt engine doesn't have a two piece timing gear with a loose aluminum center.
Old 01-18-2017, 09:32 PM   #3
SeaSlugs
SeaSlugs's Avatar
is this being started on a test stand or in the car?
If its in the car are you 100% sure its from the engine itself and not some sheetmetal somewhere?
Is it from the passenger side oil pan area, carb, distributor area, front of engine, rear of engine, drivers side oil pan, starter, generator, belt too loose, paint on the crank pulley, waterpump?
if you low idle it as slow as it will go does the squeak seem to follow the crankshaft RPM or is it faster?
Does pushing the clutch in and out change anything about the squeak?
Need some more info to point us towards a solution...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-18-2017, 10:25 PM   #4
chapsetc
Hi the engine was rebuilt by h&h . The squeak is I the front of the engine and the rattle. Is bottom left side of the engine block
Old 01-18-2017, 10:27 PM   #5
Mitch//pa
Does removing the fan belt help any
Old 01-18-2017, 10:35 PM   #6
C26Pinelake
If h & h rebuilt the engine, the problem is theirs not yours. Let them figure it out. Wayne
C26Pinelake is offline   Reply With Quote
Old 01-18-2017, 10:36 PM   #7
A31Woody
A31Woody's Avatar
Can you post a video?
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com
A31Woody is offline   Reply With Quote
Old 01-18-2017, 10:46 PM   #8
chapsetc
Well I live in Hawaii and sent it back once took for ever to get it back and now it is worse
Old 01-18-2017, 10:53 PM   #9
Tom Wesenberg
Do you know any good local mechanic that could listen to the engine?
It sounds like you have the engine in the car, so make sure the pulley isn't rubbing the frame, and make sure the front motor mount isn't squeaking on the crossmember. I like to squirt oil there to be sure. Otherwise a dry camshaft plunger is still my first bet for the squeak.
Also try it with the belt off as Mitch mentioned. I've heard lots of squeaking belts over the years.
Old 01-19-2017, 01:36 AM   #10
3.6rs
3.6rs's Avatar
I once had a rattle coming from the front of the engine ; it was the water pump.
3.6rs is offline   Reply With Quote
Old 01-19-2017, 06:59 AM   #11
macdonge
macdonge's Avatar
Water pump x 2
Sent from my SM-T560NU using Tapatalk
macdonge is offline   Reply With Quote
Old 01-19-2017, 07:00 AM   #12
macdonge
macdonge's Avatar
Ditto on water pump possibility.
Old 01-19-2017, 02:10 PM   #13
Brentwood Bob
Binding drive gear for distributor/oil pump?
Brentwood Bob is offline   Reply With Quote
Old 01-19-2017, 04:22 PM   #14
C26Pinelake
Then request satisfactory service or a complete refund! Wayne
Old 01-19-2017, 05:16 PM   #15
CarlG
CarlG's Avatar
Hi the engine was rebuilt by h&h ...
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-19-2017, 05:52 PM   #16
1929
This might not help, but once I had loud rattling and vibration noise that drove me crazy, I finally found the problem, which was 2 loose radiator brace rods.
1929 is offline   Reply With Quote
