Old 10-26-2020, 11:48 AM   #1
1stford
1stford's Avatar
Default Dehumidifier
Anyone use a dehumidifier in a garage, shop? I did not know if having one would help or hurt?
1stford is offline   Reply With Quote
Old 10-26-2020, 11:53 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Dehumidifier
Yes I use one but only when the humidity levels are high outdoors.
Helps to prevent condensation on susceptible parts.
Old 10-26-2020, 12:33 PM   #3
tubman
tubman's Avatar
I have one as well. When I had my shop built, I added a large mezzanine. The wood had a lot of moisture in it, and the dehumidifier ran almost constantly the first two years. Now, it runs only when it needs to. I think one is a necessity except where it's very dry.
Here's a hint : after I paid $159.95 for the one I wanted, I saw the exact same unit in a second-hand store for $30 a couple of days later. They had a large selection as well.
Old 10-26-2020, 01:35 PM   #4
flatford8
flatford8's Avatar
I run one all the time in my garage. The living area is over the garage so there is moisture in the building. As others have said, it runs a lot in the summer but not at all in the dry winter air. I think there a good thing to have. ..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-27-2020, 03:32 AM   #5
cajunfirehawk
cajunfirehawk's Avatar
Thumbs up Re: Dehumidifier
I live in the deep south and my 30x40x12 metal shop never got the spray foam I had hoped for before my building filled up w/my junk and cars so my shop was having lots of humidity issues until a friend recommended one. I purchased a Frigidaire FAD704DWD and it worked so well I bought a 2nd one to run too, night and day difference. One of the two can be seen in this pic on the left side, the other is on the other side of the shop not shown.
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 10-27-2020, 07:48 AM   #6
1stford
1stford's Avatar
Thanks for the info!
Old 10-30-2020, 02:47 PM   #7
Digger
Digger's Avatar
Yes have one in the shop and one in the front room, we live in a 1909 built house. They both fill up within two days, amazing how much moisture in the air here in PG
Digger is offline   Reply With Quote
Old 10-30-2020, 03:12 PM   #8
Ford46
Ford46's Avatar
I have one in the garage, garage is insulated, heated and finished in drywall and plaster. Helps to keep the moisture out in the New England weather.
Ford46 is offline   Reply With Quote
Old 10-30-2020, 03:12 PM   #9
Krylon32
Have my collector cars stored in a garage under my late model garage. We keep a dehumidifier running year around. It collects very little water in the winter but has to dumped almost every day in the summer. We keep the temperature at 60 degrees year around.
Krylon32 is offline   Reply With Quote
Old 10-30-2020, 03:34 PM   #10
PeterC
PeterC's Avatar
yes - 24/7 with a direct drain system so never need to dump condensate
PeterC is offline   Reply With Quote
Old 10-30-2020, 08:53 PM   #11
Bob T
Yes
Bob T is offline   Reply With Quote
