Old 10-05-2020, 07:51 PM   #1
Nick in Fayetteville
Default Model A Tires
AS luck would have it, I have two Model A's needing tires at the same time. That's ( 8) 19 inch tires, 8 tubes, and 8 rim liners. That's about $1700.00 as I figure it, without figuring tax and shipping. Would probably end up being over $2000.00. One car has Goodyear. The other Firestone. Question is: Has anyone used Universal or Lucas tires? I can get these for about half the price of Goodyear or Firestone. They are going on cars that don't get driven 1000 miles a year. Any good or bad experiences with either of these less expensive tires? Thank you.
Nick in Fayetteville is offline   Reply With Quote
Old 10-05-2020, 09:01 PM   #2
DBSHELTON
Default Re: Model A Tires
I have one Model A with Universals and one with European Classics. Both about $110 each they ride and drive well. No problems. Both available with free shipping. Your tubes and liners may be fine to re-use.
DBSHELTON is offline   Reply With Quote
Old 10-05-2020, 09:27 PM   #3
Chris in WNC
Chris in WNC's Avatar
CORRECTION: I just read your original posting more carefully.
Under 1000 miles per year?
Just shop price.
Tubes and liners? Look at your old tubes- if they are not cracked or splitting, re-use.
Most of my past tube failures were from being a cheapskate and running the rubber valves. The base of the valve was where they cracked.
Since I switched to original style metal valves, no more failure there.
Some older tubes are better quality than today's Chinese crap-ola.
Rim liners? I use Gorilla Tape.
"your results may vary"
our next Model A is out there in the unknown......
Last edited by Chris in WNC; 10-06-2020 at 03:29 PM. Reason: more information.....
Chris in WNC is offline   Reply With Quote
Old 10-05-2020, 09:33 PM   #4
McMimmcs
McMimmcs's Avatar
I have numerous antique cars all with GY and Firestone’s and the GoodYears have never let me down. Appearance and performance are great. But yes they are costly. Wayne
Old 10-06-2020, 07:40 AM   #5
1931 flamingo
1931 flamingo's Avatar
There's a post going on now about European Classic Tires...............109$ ea w FREE shipping.
Paul in CT
Old 10-06-2020, 09:01 AM   #6
McMimmcs
McMimmcs's Avatar
Paul in CT
This is your answer. Instead of your projected $2000 dollars it’s less than $900 including shipping. A dream come true for you!
Old 10-06-2020, 09:26 AM   #7
JD 1931
JD 1931's Avatar
Bought universals tires years ago for my 31 model a , they are just ok. Made in Vietnam and some guys will not buy them, did not know this until after I got them...
JD 1931 is offline   Reply With Quote
Old 10-06-2020, 10:35 AM   #8
duke36
Had a similar experience with the Lucas $100 tires also made in Nam. The issue is many of the budget tires have nylon cord that can exhibit flat spots after prolonged sitting.Like others have posted, I've found that this requires some driving to heat them up and avoid a bumpy ride. Go with Polyester cord if possible.
Old 10-06-2020, 10:46 AM   #9
Ruth
Really? I have Lucas tires and I have never noticed that. How long do they have to sit before the exhibit flat spots?
Ruth
Old 10-06-2020, 10:53 AM   #10
Ernie Vitucci
Good morning...I also have Lucas Tires that I bought at Arizona Model A for like $99.00 each. They are from Vietnam...they ride just fine and after 7 years and 9,000 miles I don't have any complaints...These tires were within my budget, most of the other tires were not...Ernie in Arizona
Old 10-06-2020, 10:55 AM   #11
Charlie Stephens
Is it still correct that Bratton's is the only ones that carry good tubes?
Charlie Stephens
Old 10-06-2020, 11:37 AM   #12
Purdy Swoft
Purdy Swoft's Avatar
I've had good results with the zig zag tread tires like Allstate , Garfield and others . These tires don't seem to ever wear out and I've never noticed a problem with flat spots . I've owned model A's for sixty years and counting .
Old 10-06-2020, 04:02 PM   #13
Thank you Guy for all the responses. I need to make a decision soon...Nick
Old 10-06-2020, 04:17 PM   #14
duke36
I've been following this thread to see others' experiences. If the car sits for a week or 2, the tires retain a flat spot with only about 500 miles on them at 35 psi. When pushing the car forward a few inches, the car rolls back to the flat spots. It takes a few minutes driving for the flat spots and thumping to dissipate. Otherwise, they ride fine, look great and fit in the fender wells with 30 to 32psi.
Old 10-07-2020, 05:54 PM   #15
Cpuckett
I put Lucas on mine with new tubes and liners. I thought they looked very nice. Will probably dry rot as I don’t drive it much. About 100.00 each plus tubes/liners
Cpuckett is offline   Reply With Quote
Old 10-08-2020, 01:31 PM   #16
mhsprecher
mhsprecher's Avatar
My understanding is that the Bratton's tubes are good quality. I have no direct experience, however. I have Excelsior radials on my 30 and some old Garfields on my 28, fwiw.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 10-10-2020, 05:48 AM   #17
RonC
RonC's Avatar
Charlie Stephens
Yes
RonC is offline   Reply With Quote
Old 10-10-2020, 06:32 AM   #18
McMimmcs
McMimmcs's Avatar
I was told that Snyder’s carry exactly the same tubes!
Old 10-10-2020, 11:37 AM   #19
Benson
Benson's Avatar
I was told that Bert’s carry exactly the same tubes!
www.modelastore.com
Old 10-10-2020, 04:29 PM   #20
Patrick L.
Patrick L.'s Avatar
Mine are about 40 yrs old and won't wear out. I'm not buying new ones until they do so I think I'll wear out before they do.
