Old 06-22-2020, 04:09 PM   #1
doug.nichols
doug.nichols's Avatar
Question 28/29 Brake Light Switch
I have purchased a new brake light switch from Snyder's for my 29. But, after reading many threads about defective repro switches, I am reluctant to install it. Is there any consensus on what the best repro switch is for 28/29? (I know, I used the word "consensus" ... which seems unlikely).
doug.nichols is offline   Reply With Quote
Old 06-22-2020, 05:08 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: 28/29 Brake Light Switch
The spendy one. $50.00. I think A&L makes them for the vendors. Love mine. (30-31)
Tacoma Bob is offline   Reply With Quote
Old 06-22-2020, 05:11 PM   #3
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
A&L only does wholesale now. Call brattons or snyders and ask them for that one...
Mark Maron
Ill., Region MARC & MAFCA
27A's, MARC JSC Member
2021 Oshkosh National Meet Chief Judge
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
msmaron is offline   Reply With Quote
Old 06-22-2020, 05:18 PM   #4
Bob C
This video may help to make sure yours is ok.
https://www.youtube.com/watch?v=zsfWFf80Y70
Old 06-22-2020, 05:32 PM   #5
rotorwrench
rotorwrench's Avatar
The 28 & 29 types generally have less problems than the later 30/31. The problems are easier to repair as seen in the video.
Old 06-22-2020, 06:07 PM   #6
Russ/40
Russ/40's Avatar
On the 28/29 switch, it is easy to repair. On some, the spring when fully compressed, if short, can pull the overall shaft out of the rear of the unit rendering it brake lights on full time. I put threads on the very end of the shaft, and double nutted it so it can't be pulled through. This is only a problem if your brakes are far out of adjustment with a long brake pedal stroke.
Russ/40 is online now   Reply With Quote
Old 06-23-2020, 08:52 AM   #7
ryanheacox
ryanheacox's Avatar
Almost positive A&L only makes 30-31 stop light switch. For 28-29 you're stuck with a cheap repro. You could also call Berts and see if they have a good original there.
Old 06-23-2020, 11:02 AM   #8
Russ/40
Russ/40's Avatar
Yes, your correct. Only the 30/31.
Old 06-23-2020, 09:58 PM   #9
700rpm
700rpm's Avatar
Get an original one anywhere you can. A&L probably makes a good one, but originals can sometimes be found for less than $10 at swap meets. I’ve given up on the repros. Too bad the Portland Swap Meet was cancelled this year.
Ray Horton, Portland, OR
Old 06-24-2020, 09:18 AM   #10
doug.nichols
Thank Ray. I think I will go on the hunt for an original.
Old 06-24-2020, 11:10 PM   #11
700rpm
700rpm's Avatar
You could try Tom at Model A Ford Works in Portland. He has a lot of original stuff. 503-410-1091.
Old 06-24-2020, 11:19 PM   #12
Synchro909
Synchro909's Avatar
The switches available from the vendors are no good on RHD cars. Does anybody know what the RHD switches looked like and how they were installed?
Yesterday is History.
Tomorrow is a mystery.
Enjoy Today.
Old 06-25-2020, 12:20 AM   #13
Bill G
Bill G's Avatar
Yes, and I was getting all excited to go this year.
-Bill G
Member of Walla Walla Sweet A's Model A Club
Old 06-25-2020, 10:07 AM   #14
Bob C
Here you go.
Old 06-30-2020, 07:06 PM   #15
Wagga A'er
Hi Synchro.
The switch was installed on the right hand side chassis rail. The metal used is much thicker than the repro LHD switch. It is basically a flat plate with a half cylinder cover that is held in place with some small tabs. The spring inside is very strong. I can dig out some pics if you wish? Just let me know. My switch is off and early 28 Australian "Tourer"
Wagga A'er is offline   Reply With Quote
