Old 01-21-2020, 03:53 PM   #1
doug.nichols
doug.nichols's Avatar
Smile Corn Head Grease Too Fluid for Gun
Has anybody else had the problem of corn head grease being too fluid to be pumped by a standard grease gun? The plunger just moves through the grease tube without pushing much out the nozzle.
doug.nichols is offline   Reply With Quote
Old 01-21-2020, 04:16 PM   #2
jb-ob
Default Re: Corn Head Grease Too Fluid for Gun
Define 'standard'.....modern ???
Probably not helpful but, I had no problem using an original Model A factory grease gun.
jb-ob is offline   Reply With Quote
Old 01-21-2020, 04:18 PM   #3
oldforder
oldforder's Avatar
I have a grease gun with "00" grease in it with no problem.
oldforder is offline   Reply With Quote
Old 01-21-2020, 05:49 PM   #4
doug.nichols
yes, modern
Old 01-21-2020, 06:13 PM   #5
7_Zero
7_Zero's Avatar
I have the same problem, figured it was due to a cheap gun but have not tried a different one yet. It takes about 10 pumps of Corn Head grease to equal 1 pump of chassis grease and I have to keep resetting the plunger.
Maybe the original style gun would be better suited for this type of grease. Will have to try it as soon as I figure out where it is.
7_Zero is offline   Reply With Quote
Old 01-21-2020, 06:34 PM   #6
rotorwrench
rotorwrench's Avatar
I've used up a lot of grease guns over the years for the older helicopters. Some are designed for cartridges and some are not. Some are just plain not well designed at all. The ones that have too loose a plunger seal may leak the grease past the seal into the spring cavity. If it does this, the gun will never work for the thin greases.
The pump piston in most grease guns is pretty small so they don't have a lot of displacement. I've had troubles bleeding the air out of some guns. It can take forever on poorly designed units.
I've not tried to use a suction gun such as is used for gear lube but it may work with the corn header gearbox grease.
Old 01-21-2020, 07:30 PM   #7
TMarsh
I used a cheap air grease gun from HF. Worked OK for me.
TMarsh is offline   Reply With Quote
Old 01-21-2020, 09:59 PM   #8
fundytides
fundytides's Avatar
I use a Harbor Freight type gun as well (Princess Auto here in Canada) to pump corn head grease into the rollers on my John Deere crawler. I use John Deere corn head grease and I assume it's similar weight to other corn head grease and I don't have any problem with the gun. I also use an adapter for the button head fittings but I don't think that make a difference. I would say it must be an issue with your gun.
fundytides is offline   Reply With Quote
Old 01-22-2020, 01:04 AM   #9
SSsssteamer
SSsssteamer's Avatar
Ditto on all of the above, except, I am in the USA.
SSsssteamer is offline   Reply With Quote
Old 01-22-2020, 02:01 AM   #10
Kurt in NJ
Kurt in NJ's Avatar
If the grease gun is made to use cartriges the piston is smaller to fit in the cartrige, try it with empty grease cartrige
Old 01-22-2020, 10:54 AM   #11
katy
katy's Avatar
FWIW, years ago I was shown that if you remove the nipple or hose coming out of the grease gun before bleeding it will bleed the air out much easier.
Old 01-22-2020, 05:00 PM   #12
doug.nichols
Great information, as usual.
Thanks
Old 01-22-2020, 05:21 PM   #13
Jeff M
I have a tube in a harbor freight gun, test pumped fine. I need to pump it into my steering box. Are you guys screwing in a zerk into the fill hole for that?
Jeff M is offline   Reply With Quote
Old 01-22-2020, 09:04 PM   #14
J Franklin
J Franklin's Avatar
Many do just that, but then make the mistake of using non fluid grease or gear oil. That is why Ford switched to a plug early on.
Old 01-26-2020, 09:29 AM   #15
bobsmanstuff
bobsmanstuff's Avatar
I used a big plastic syringe.
bobsmanstuff is offline   Reply With Quote
Old 01-27-2020, 11:40 AM   #16
duke36
The corn head may need to be stirred in the tube cannister. I put it in the refrig. for a short period to help coagulate.
I drill out an extra 2 tooth box plug and tap a hole for a small zerk. Then one can inspect fluid level and pump more if needed.
