Old 11-26-2020, 04:18 PM   #1
mgambuzza
mgambuzza's Avatar
Default Replacing float and kit for 1930 Gas Gauge
I received my rebuild kit from Snyders (cork gaskets) but I did have a question. Do I need to use gasket cement anywhere on the reassembly, or just the corks by themselves?
I did order another kit originally but they were the neoprene gaskets. I saw a couple forums not recommending neoprene so I ordered a cork set.
mgambuzza is offline   Reply With Quote
Old 11-26-2020, 04:37 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Replacing float and kit for 1930 Gas Gauge
No need for a sealant. In fact using one could make it near impossible to take out again in the future.
Old 11-26-2020, 04:49 PM   #3
DBrer
I agree, I installed mine with no sealant and no leaks.
DBrer is offline   Reply With Quote
Old 11-26-2020, 05:04 PM   #4
mgambuzza
mgambuzza's Avatar
Question - I just noticed the replacement I received was a cork/neoprene gasket in the kit. Should I proceed with this, or look for a company that makes a "true" cork kit for the gas gauge?
Old 11-26-2020, 05:23 PM   #5
TMarsh
The cork needs sealant on it or a float that will not sink eventually when exposed to gasoline
TMarsh is offline   Reply With Quote
Old 11-26-2020, 05:27 PM   #6
Ruth
I use the cork/neoprene gaskets from Snyder's with no problems, no sealant needed. Get the brass slip ring also. I don't believe it is included with the gasket set.
Ruth
Old 11-26-2020, 06:18 PM   #7
mgambuzza
mgambuzza's Avatar
Thanks all - I'll let you know how I work out. I can see the old cork attached and intact(thankfully). If I pull it up with a coat hanger it drops like a sinker once released. The kit came with the neoprene float.
Old 11-26-2020, 09:02 PM   #8
mgambuzza
mgambuzza's Avatar
Success thank you!!
Old 11-26-2020, 11:07 PM   #9
quickchange
quickchange's Avatar
use maple syrup on cork gaskets, done dozens , down under use golden syrup,
quickchange is offline   Reply With Quote
Old 11-27-2020, 10:46 AM   #10
gary678*
Just do not buy it from Macs; the brass ring did not fit so I had to use the old one. No more Macs for me!
gary678* is offline   Reply With Quote
Old 11-27-2020, 10:51 AM   #11
Jack Shaft
Love food based tricks..maple syrup?cool and you can lick your fingers to clean up!!
Old 11-27-2020, 11:41 AM   #12
Mister Moose
Mister Moose's Avatar
Are we talking corn syrup imitation maple syrup, or 100% real deal maple syrup?
Either way, I'm highly skeptical of this idea. The anti seize or sealing aspect, not the finger licking.
Mister Moose is offline   Reply With Quote
Old 11-27-2020, 08:06 PM   #13
quickchange
Mr moose ,?? e use golden syrup , as had no maple syrup , both work , petrol (gas) does not dissolve it, been using it some 40 years on the cork seals, never had a leak ,If you are highly skeptical then don,t do it , Some of the good great folk no longer post on here with tried tips as we get pissed off with knockers,
